FME Transformers: 2024.1
StringLengthCalculator
Calculates the length of strings and the number of bytes in a blob.
Example
To calculate the number of bytes in a blob:
- Add a raster format reader (for example, TIFF).
- Connect a RasterExtractor followed by a StringLengthCalculator.
- In the StringLengthCalculator parameters, select _rasterBlob as the Source Attribute.
- Connect an Inspector transformer.
- Run the workspace.
Locate the _length attribute name in the Information Window:
Note that in non-ASCII character sets, the length is the number of actual characters (some or all of which could be multi-byte) in the string, which may not match the number of bytes used to store the string.
Source Attribute |
After connecting the transformer, select the source attribute from the list. |
String Length Attribute |
This attribute contains the resulting value. |
Search for all results about the StringLengthCalculator on the FME Community.
