FME Transformers: 2024.1
SharePointOnlineConnector
Accesses SharePoint Online to upload, download, or delete files and folders or list file/folder information.
- Manage files on SharePoint Online by uploading, downloading, and deleting files and folders.
- Transfer a file's contents (such as XML or raster) into or out of an attribute in FME.
- Retrieve file and folder names, paths, links and other information from SharePoint Online to use elsewhere in a workspace.
The SharePointOnlineConnector uses your SharePoint Online account credentials (either via a previously defined FME web connection, or by setting up a new FME web connection right from the transformer) to access the file storage service.
Depending on your choice of actions, it will upload or download files, folders, and attributes; list information from the service; or delete items from the service. On Upload and List actions, links and file/folder information are added to the output features as attributes.
Authentication
The SharePointOnlineConnector uses an oauth web service defined FME web connection. It is recommended to create a new web connection using the Microsoft SharePoint Online (safe.microsoft-sharepoint) web service. It is also recommended to replace the included FME app client with your own defined oauth application by updating the client id and secret in SharePoint Online (safe.microsoft-sharepoint).
SharePoint supports only work or school Microsoft accounts.
- This transformer cannot be used to directly move or copy files between different SharePoint Online locations. However, multiple SharePointOnlineConnectors can be used to accomplish this, by downloading files/folders and re-uploading them to a new location.
- The FeatureReader can access SharePoint Online directly, without using the SharePointOnlineConnector. In this case, a permanent local copy of the data will not be created.
The output of this transformer will vary depending on the action performed.
- A Delete action will output the incoming feature.
- A Download action will output the incoming feature and can save to either a file, folder or attribute.
- A List action will output a new feature for each file/folder found in the path specified. Each of these new features will have attributes listing various pieces of information about the object.
- After an Uploadaction, selected information about the file will be available as attributes.
The incoming feature is output through this port.
Features that cause the operation to fail are output through this port. An fme_rejection_code attribute describing the category of the error will be added, along with a more descriptive fme_rejection_message attribute which contains more specific details as to the reason for the failure.
Account |
To create a SharePoint Online connection, click the 'Account' drop-down box and select 'Add Web Connection...'. It is recommended to use the SharePoint Online Web Service. The connection can then be managed via Tools -> FME Options... -> Web Connections. |
Action |
The type of operation to perform. Choices include:
The remaining parameters available depend on the value of the Request > Action parameter. Parameters for each Action are detailed below.
Delete Options
Site |
The id of the sharepoint site. You may browse for a site. |
Document Library |
Also known as a drive on a site. A site can have multiple document libraries, which can be browsed. |
Path |
The full path of a file or folder on SharePoint Online to delete. A drive item id is also accepted. SharePoint prohibits deleting the root of a document library. |
Download Options
Site |
Document Library |
Path |
The full path of a file or folder on SharePoint Online to download. A drive item id is also accepted. |
Destination
Download as |
Select whether to store the downloaded data in a File, Folder or Attribute.
Download to Attribute |
Specify the attribute that will store the contents of the downloaded file. Valid for Download as Attribute only. |
Response Body Encoding |
For Download as Attribute, you can specify a character set encoding to ensure the output is in a human-readable form. If Auto Detect from HTTP Header is specified but there is no encoding in the Content-Type metadata associated with the data, the output will be returned as raw bytes. |
Download to Folder |
Specify the path to the folder that will store the downloaded file. Valid for Download as File or Folder. |
If File Exists |
Specify what to do if the file already exists locally. Valid for Download as File or Folder.
Include Subfolders |
Choose whether to download subfolders of the SharePoint Online source or not. Valid for Download as Folder only. |
Output Attributes
The selected attributes will be added to the output feature.
_download_path |
Path of the downloaded object on the local file system. This attribute will not be added for Download as Attribute. |
List Options
Site |
Document Library |
Path |
The full path to the folder on SharePoint Online to list. A drive item id is also accepted. |
If set to Yes, then subfolders are recursively traversed, and their contents are included in the result. |
Output Attributes
_name |
Name of the file or folder. |
_id |
Drive item id of the file or folder. |
_full_path |
Full path of the file or folder relative to the document library, prefixed with ‘/’. |
_document_library |
The document library of the file or folder. |
_extension |
The extension of the file. |
_list_id |
Id of the SharePoint List. |
_list_item_id |
Numeric id of the item in the SharePoint List. |
_url |
URL to the file or folder. |
_file_or_folder |
Whether the item is a file or a folder. |
_file_size |
File size (not present for folders). |
_created |
Date and time when the file was created. |
_created_by |
Name of user who created the file or folder. |
_last_modified |
Date and time when the file was last modified. |
_last_modified_by |
Name of user who last modified the file or folder. |
Data Source
Upload |
The type of data to be uploaded.
When working with large objects, File is a better choice than Attribute as the data will be streamed directly from disk and not require that the object be stored entirely in memory on a feature. When wanting to upload content from a folder, it is better to upload as a folder instead of setting a fixed path and sending multiple features into the connector to upload as a file. |
File to Upload |
The file to be uploaded to SharePoint Online if Upload is set to File. |
Folder to Upload |
The folder to be uploaded to SharePoint Online if Upload is set to Folder. |
Choose whether to upload subfolders of the Folder to Upload or not. |
Contents Only |
Attribute to Upload as File |
The data to be uploaded, supplied from an attribute if Upload is set to Attribute. |
Upload Options
Site |
The id of the SharePoint site. You may browse for a site. |
Document Library |
Upload with File Name |
The name of the file created from the data supplied in Attribute to Upload as File. The name must include a filename extension (for example, .txt, .jpg, .doc). |
If File Exists |
Specify what to do if the file already exists on SharePoint Online.
Create Sharing Link
If checked, a sharing link will be generated for the uploaded file. The attribute _sharing_link will be added to the output feature.
Permissions |
Scope |
Expiration Date |
Optional. The expiration time of the permission. Not available when scope is organization. |
Output Attributes
_name |
_id |
_full_path |
_document_library |
_extension |
_list_id |
_list_item_id |
_url |
_file_or_folder |
_file_size |
_created |
_created_by |
_last_modified |
_last_modified_by |
| Dependencies | SharePoint Online Account |
| History | Released FME 2019.0 |
Search for all results about the SharePointOnlineConnector on the FME Community.
