FME Transformers: 2024.1
FeatureReader
Reads features from any FME-supported format.
A complete read is done for each feature that enters the Initiator port. The features resulting from the read are output either through named output ports or through the generic output port.
The features read can be constrained by specifying a WHERE clause or a spatial filter for formats that support them. Most reader settings and constraints can be configured dynamically from attribute values on the input features.
Additionally, a schema feature representing the feature type definition is output for each encountered feature type. The schema features can be used to configure feature type definitions for dynamic writing.
Example
Receives features that initiate feature reading.
Output port for schema features. If connected, a schema feature is produced for each unique feature type encountered during read. The schema feature is guaranteed to be output before any data features of the same feature type and is output only once per translation.
Note that schema features receive a new attribute fme_schema_handling with the value schema only. This attribute is used in writers to indicate that the feature should be used to define a schema only and then discarded, and so care should be taken if subsequently merging with other features.
Schema reading may affect performance. If the schema feature output port is not connected or Features to Read is set to Data Features, then schema reading will not occur and there will be no performance penalty. If a list of feature types to read was specified then schema reading will stop as soon as schemas for all the listed feature types have been output. If no feature types to read were listed, then schema reading will occur on every Initiator feature.
Performance can be improved when only reading schemas by configuring the transformer to not read data features. This is done by setting Features to Read to Schema Features or by ensuring that the <Generic>, the <Initiator>, and the named feature type output ports are not connected.
Parameters for Constraints or for Attribute and Geometry Handling do not apply to schema features.
Generic output port for features that do not have a corresponding named output port.
Upon read success, outputs the original Initiator features with the addition of the _matched_records attributes which holds the number of data features read for that Initiator feature.
Upon reader error, outputs the original Initiator feature with the addition of the _reader_error attribute which contains the last error message from the reader.
Output Ports can be optionally generated for all or a subset of the feature types available to read.
Reader |
Select the Reader format and dataset, including any reader-specific parameters. |
Constraints |
Schema/Data Features |
Enable Cache |
Accumulation Mode |
Merge Initiator and Result: Output features will contain all of the un-conflicted attributes from the results of the read as well as any un-conflicted attributes from the Initiator feature. This mode will handle conflicted attributes based on the Conflict Resolution parameter. Only Use Result: Output features will contain only attributes resulting from the read. Only Use Initiator: Output features will contain all of the attributes from the Initiator feature, but none of the attributes resulting from the read. Prefix Initiator: Output features will contain attributes resulting from the read, as well as attributes from the Initiator feature but with the Initiator attribute names prefixed with the Prefix parameter. |
Conflict Resolution |
Use Result: If a conflict occurs, the values resulting from the read will be used. Use Initiator: If a conflict occurs, the values of the Initiator will be used. |
Ignore Nulls |
Enabled when Accumulation Mode is set to Merge Initiator and Result. If Yes, where there are attributes with the same name on both Initiator and Result feature, if one has a value of <null> then the other attribute value will be used. If No, the Conflict Resolution selection will be strictly observed, including keeping null values. |
Prefix |
If the Accumulation Mode parameter is set to Prefix Initiator, this value will prefix attributes from the Initiator feature. |
Geometry |
Result: The feature geometry from the results of the read is used. Initiator: The feature geometry from the Initiator feature is used. Aggregate Initiator and Result: The feature geometry is an aggregate of the geometry from the Initiator feature followed by the geometry from the result of the read. The aggregate geometry will be tagged with the coordinate system from the result of the read. The Initiator geometry will not be reprojected. This can create unexpected results if it is in a different coordinate system. For best results, ensure the Initiator geometry has the same coordinate system as the geometry being read. |
<Generic> Port
Attributes to Expose |
Enter the names of attributes to expose on the <Generic> output port. The attributes will be ordered in the same sequence as specified in the list. |
Search for all results about the FeatureReader on the FME Community.
Keywords: query Querier OracleQuerier RasterReader
