FME Transformers: 2024.1
MGRSToLatLongConverter
Determining the center point of the area represented by a standard MGRS code.
The MGRSToLatLongConverter accepts any feature. The user specifies an attribute, expression, or user parameter containing a valid MGRS Code, along with the Ellipsoid and appropriate Lettering Type.
The coordinates of the center point of the described area are added as attribute values. The size of the area (and so the position of the center point) depends on the precision of the MGRS code, ranging from 1 meter square to 100 km square. See LatLongToMGRSConverter for more information.
In this example, we have a CSV file of cities with associated MGRS codes. They have no geometry.
The features are routed into an MGRSToLatLongConverter.
In the parameters dialog, MGRS Code is set to the appropriate attribute. Default attribute names are kept for the coordinates output.
The output features now have attributes containing latitude and longitude coordinates representing the center of the area described by each MGRS code.
Note that in this case, that area is 1 meter square, as the MGRS codes have a precision of 5.
For more information on the MGRS, see Military Grid Reference System.
This transformer does not create geometry. To create points from the coordinates, consider using a VertexCreator.
Features with MGRS codes available as attributes, expressions, or user parameters.
Features with latitude and longitude coordinates generated according to parameter selections and added to attributes.
Ellipsoid |
The ellipsoid used for the conversion. This can be any ellipsoid name supported by FME. |
Lettering Type |
Select a type:
MGRS Code |
Supply an MGRS code by providing an attribute name, expression, or user parameter. |
Longitude |
Name the attribute to contain the generated longitude value. |
Latitude |
Name the attribute to contain the generated latitude value. |
Search for all results about the MGRSToLatLongConverter on the FME Community.
