FME Transformers: 2024.1
LatLongToMGRSConverter
Calculates a Military Grid Reference System (MGRS) code based on latitude and longitude values.
Determining which standard MGRS boundary contains a given point.
The LatLongToMGRSConverter accepts any feature. The user specifies attributes, expressions, or user parameters containing latitude and longitude coordinates, along with the Ellipsoid and desired Lettering Type.
The standard MGRS code is generated to the specified Precision, and stored as an attribute.
Precision is an integer from 0 to 5 (inclusive). A precision of 5 locates a point within a 1-meter square and precision of 0 locates a point within 100-km square.
In this example, we have a shapefile of food vendor locations, and want to generate MGRS codes for each location.
Note that although the dataset is in a UTM coordinate system with ground units in meters, it also has a set of coordinates, latitude and longitude, stored as attributes.
The features are routed into a LatLongToMGRSConverter.
In the parameters dialog, Precision is set to 5, and the Longitude and Latitude parameters are set to the appropriate attributes.
The output features have a new attribute containing the resulting code.
For more information on the MGRS, see Military Grid Reference System.
This transformer does not operate on geometry. To extract coordinates from geometry for conversion, consider using the CoordinateExtractor or @XValue() and @YValue() functions.
Features with latitude and longitude coordinates available as attributes, expressions, or user parameters.
Features with an MGRS code generated according to parameter selections and added to an attribute.
Ellipsoid |
The ellipsoid used for the conversion. This can be any ellipsoid name supported by FME. |
Lettering Type |
Select a type:
Precision |
Specify the granularity of the resulting code an integer from 0 to 5.
Longitude |
Supply a longitude value by providing an attribute name, expression, or user parameter. |
Latitude |
Supply a latitude value by providing an attribute name, expression, or user parameter. |
MGRS Code |
Name the attribute to contain the generated MGRS code. |
Search for all results about the LatLongToMGRSConverter on the FME Community.
