FME Transformers: 2024.1
BulkAttributeRenamer
- Rename multiple attributes to match a naming convention
- Add prefixes or suffixes to attribute names
- Remove prefixes or suffixes from attribute names
- Change the case of attribute names
- Replace a string in attribute names
The BulkAttributeRenamer lets you select either all attributes or specific ones, and then choose a renaming method. All attributes on features that enter the transformer are modified according to your selections.
If the renaming process results in an empty attribute name, that attribute will be removed - for example, removing a suffix where the suffix itself is the whole attribute name.
The values of attributes are unchanged.
In this example, a prefix is added to all of the attributes.
The output attribute names are altered as requested.
- This transformer is specifically for changes to attribute names. To change attribute values use the StringReplacer or AttributeManager transformers.
- Use the AttributeManager to rename individual attributes, with the option of supplying a default value if the original attribute was not present.
- Use the StringCaseChanger to change the case of attribute values (not names).
- If Rename All attributes is chosen, unexposed format attributes may also be renamed, which may produce unexpected results. Consider using Selected Attributes and the attribute pick list for finer control.
Features with attributes.
Features with renamed attributes.
Rename |
Choose either All Attributes or Selected Attributes. |
Selected Attributes |
If you choose to rename Selected Attributes, this is enabled, along with an attribute picker. Select the attributes you want to rename. Note that internal FME attributes that have been exposed begin with βfme_β. Renaming these may produce unexpected results. |
Action |
Select the type of renaming you want to do to the attributes chosen above. Options include:
Mode |
Whether or not the original attribute names should be kept in addition to the new ones.
Text To Find |
When using the Regular Expression Replace or String Replace actions, enter the item you would like to replace here. The replacement string goes in the String parameter. If the Action parameter is set to Regular Expression Replace, the Regular Expression Editor will be available in the Text To Find parameter menu. |
Case Sensitive |
Indicate whether or not the comparison should be case-sensitive. |
String |
The character sequence to prepend, remove, append, or use as replacement string. |
Case Change Type |
For use with the Change Case action.
| History | Replaces the AttributePrefixer and the AttributeExpressionRenamer |
Search for all results about the BulkAttributeRenamer on the FME Community.
Examples may contain information licensed under the Open Government Licence β Vancouver, Open Government Licence - British Columbia, and/or Open Government Licence β Canada.
