FME Transformers: 2024.1
BulkAttributeRemover
- Remove multiple attributes from features where the attribute names have something in common, such as a prefix, suffix, string, or a pattern that can be described with a regular expression.
The BulkAttributeRemover lets you enter a regular expression - which may be as simple as a specific series of characters, or as complex as you like, using Advanced Regular Expression syntax.
Any attributes with a portion of their name matching your expression are removed, and all other attributes pass through the transformer untouched.
Matches are case-sensitive.
In this example, attributes containing the string “OWNER” are removed to anonymize the data.
Non-matching attributes pass through untouched, and the two attributes that do match are removed from the output.
- Use the AttributeManager to remove selected individual attributes from a feature.
- Use the AttributeKeeper to remove large numbers of attributes without expression matching, and keep selected individual attributes on a feature.
- This transformer will not remove fme_ attributes - to remove them, use either the AttributeRemover or AttributeManager.
Features with attributes.
Features with attributes that match the specified regular expression removed.
Expression to Remove |
Enter a regular expression that specifies what string an attribute name needs to contain for it to be removed. For example, to remove AutoCAD format attributes from a feature, specify: ^autocad_.* Or to remove all attributes containing the string “INTL”, simply enter INTL. You can test expressions by using the Regular Expression Editor, accessed through the drop-down parameter menu. For more information on constructing expressions, see Regular Expression Editor. |
| History | Replaces the AttributeExpressionRemover |
Search for all results about the BulkAttributeRemover on the FME Community.
