FME Transformers: 2024.1
AttributeExploder
Creates value pairs (attribute name and attribute value) for every attribute on a feature, and either adds them to a list attribute or creates new features (one for each pair) with new attributes containing both values.
In either case, original attributes and geometry may be kept or discarded.
- Transposing or manipulating tabular data (such as spreadsheets)
- Melting data
- Extracting the attribute schema from features for use in dynamic translation attribute mappings
- Extracting the attribute schema from features to write as metadata/documentation
- Preparing data for charts and reports
The AttributeExploder receives features with attributes, and extracts both the attribute names and their values. It can do one of two things with them (the Exploding Type) - either create multiple new features (one for each attribute), or add the information to the original feature as a list attribute.
The following examples demonstrate both Exploding Types, as they apply to a single feature. Note that in both cases, extra attributes that are normally unexposed are also exploded, including reader and internal fme_ attributes.
You may opt to either keep or discard the original attributes and geometry - in these examples, they are discarded.
Exploding Type: Features
If the attributes are exploded into Features, each input feature will become many - one for every attribute in the original feature. The new features will have both the original attribute names and values added as new attributes. Below, we use the default new attribute names _attr_name and _attr_value.
One (1) feature becomes twelve (12).
In the case of a spreadsheet, where a row is considered a single feature, this is the equivalent of exploding every cell into its own feature.
Exploding Type: List
If the attributes are exploded into a List, a new list attribute is added to the original feature.
The attribute names and values are added as list elements.
One (1) feature in produces one (1) feature out, with a list attribute.
Excluding Attributes
AttributeExploder processes all attributes on incoming features, including fme_ and format attributes. It is possible to ignore attributes using the Ignore Attributes Containing parameter.
Enter a regular expression, and matching attributes will be ignored.
For example, if the source data is CSV, you could use the regular expression ^fme_|^multi_|^csv_ to ignore any attributes starting with fme_, multi_, or csv_.
In this example, we will use an AttributeExploder to write out the attributes of a MrSID raster for documentation. One raster tile is considered a single feature.
In the AttributeExploder parameters dialog, the Exploding Type is set to Features, and the default Output Attribute Names are kept.
As the output will contain extra attribute types that we don’t want (reader and fme_ internal attributes), we configure a Tester to keep only features where _attr_name begins with the string “mrsid”.
With an Excel writer, a spreadsheet is created (one row per feature), containing both the attribute names and values for the original raster.
- The AttributeExploder is commonly used in manipulating tabular data, from simple transposition to more complex tasks. See articles on the FME Community for detailed examples.
- To unmelt (reverse melt) data, see the AttributeCreator (alias UnMelter).
Features with attributes.
Features containing the attribute value pairs. Depending on Exploding Type, this may be multiple features with pairs as attributes, or single features with a list attribute added.
Exploding Type |
Features: One feature is output for each original attribute. Each output feature will have two new attributes: one named by Exploded Attribute (whose value will be the initial attribute's name) and one by Exploded Value (whose value will be the initial attribute's value). List: The processed feature will have a new list attribute defined by List Name which will contain one entry (with attribute name and attribute value members, named by Exploded Attribute and Exploded Value) for each attribute of the feature. Note List attributes are not accessible from the output schema in FME Workbench unless they are first processed using a transformer that operates on them, such as ListExploder or ListConcatenator. Alternatively, AttributeExposer can be used.
Keep Geometry |
If Yes, each output feature will have the same geometry as the given input feature. Otherwise, output features will have no geometry. |
Keep Attributes |
If Yes, the initial attributes on the processed features are preserved. Otherwise, output features will only have the attributes created by this factory. |
Ignore Attributes Containing |
Enter a regular expression. Attributes with matching names will be excluded. |
Ignore Attributes |
Select case sensitivity - Case Sensitive or Case Insensitive -for Ignore Attributes Containing regular expression matching. |
Exploded Attribute |
Name the attribute to contain the name of the extracted attribute. |
Exploded Value |
Name the attribute to contain the value of the extracted attribute. |
List Name |
If Exploding Type is List, enter a name for the list attribute. |
| Aliases | Melter |
Search for all results about the AttributeExploder on the FME Community.
