RasterGCPExtractor
                                            Extracts Ground Control Point (GCP) coordinate system and point values from a raster feature and exposes them as attributes.
- Extracting GCP raster properties to an attribute for use elsewhere in a workspace.
The RasterGCPExtractor receives raster features and extracts any Ground Control Points (GCPs) that exist as a raster property on the input feature. The following attributes are added to the output features:
                                                             _gcp_coordsys  |
                                                             The GCP coordinate system.  |
                                                             _gcp_value  |
                                                             All existing GCPs, as a string. Each GCP has five components, separated by spaces: Column Row X-Coordinate Y-Coordinate Z-Coordinate For example: 1442 6863 483000 5456000 0 Multiple GCPs are combined into one string, separated by semicolons: 1442 6863 483000 5456000 0;1415 1143 483000 5468000 0;4754 1120 490000 5468000 0  |
The GCPs are not removed from the raster properties, and so exist as both properties and attributes on the output features.
In this example, we will extract the GCP coordinate system and values from a GeoTIFF raster.
Note that the source raster has GCPs stored as raster properties.
The raster is routed into a RasterGCPExtractor.
There are no parameters to configure.
The output raster feature has new attributes containing the GCP Coordinate System, and the GCP points as a string. The original GCP raster properties remain intact.
Choosing a Raster Transformer
Working with Rasters
        Sets the cell origin point within cells in a raster.  |
        Applies a convolution filter (sometimes called a kernel or lens) to raster features and outputs the results.  |
        Evaluates expressions on each cell in a raster or pair of rasters, including algebraic operations and conditional statements.  |
        Replaces the geometry of input raster features with a polygon covering either the extents of a raster or the extent of data within a raster.  |
        Extracts Ground Control Point (GCP) coordinate system and point values from a raster feature and exposes them as attributes.  |
        Sets Ground Control Points (GCPs) on a raster, pairing cell positions with known coordinates.  |
        Georeferences a raster by either known corner coordinates or origin, cell size, and rotation.  |
        Generates a grayscale shaded relief representation of terrain, based on elevation values.  |
        Alters the interpretation type of rasters, including all bands, and converts cell values if necessary.  |
        Merges multiple raster features into a single raster feature.  |
        Extracts the geometry properties of a raster feature and exposes them as attributes.  |
        Resamples rasters to multiple resolutions, based on either number of levels or dimensions of the smallest output raster.  |
        Transforms an image to minimize its difference with another.  |
        Resamples rasters, based on specified output dimensions, cell size in ground units, or percentage of original, and interpolates new cell values.  |
        Rotates a raster feature according to its rotation angle property, interpolating new cell values, updating all other affected raster properties, and producing an output raster feature with a rotation angle of zero.  |
        Enhances the features of a raster image. The RasterSharpener enhances the borders, lines, and curves while reducing noise in the flat areas of the raster image.  |
        Clips raster features using pixel bounds instead of ground coordinates, and optionally adds cells around the perimeter.  |
        Splits each input raster into a series of tiles by specifying either a tile size in cells/pixels or the number of tiles.  |
        Creates polygons from input raster features. One polygon is output for each contiguous area of pixels with the same value in the input raster.  |
        Creates a series of image tiles that can be utilized by web mapping applications such as Bing™ Maps, Google Maps™, or Web Map Tile Service. This is done by resampling rasters to various different resolutions and then splitting them into tiles.  |
Working with Bands
        Adds a new band to a raster feature.  |
        Merges coincidental raster features into a single output raster feature, preserving and appending all bands.  |
        Alters the interpretation type of individual raster bands, converting cell values if necessary.  |
        Removes all unselected bands from a raster feature.  |
        Extracts the minimum and maximum band values, palette keys, and palette values from a raster feature, and adds them to a list attribute.  |
        Sets the band name of selected bands on a raster, making raster contents simpler to understand compared to band numbers.  |
        Removes the existing Nodata identifier from selected bands of a raster feature. Any values previously equal to the Nodata value are considered valid data.  |
        Sets a new Nodata value on selected bands of a raster feature.  |
        Specifies the required order of bands in a raster. Bands are reordered according to the input band indices.  |
        Extracts the band and palette properties of a raster feature and exposes them as attributes.  |
        Removes any selected bands from a raster feature.  |
        Separates bands or unique band and palette combinations, and outputs either individual raster features or a single new raster feature containing all combinations.  |
        Calculates statistics on raster bands and adds the results as attributes.  |
Working with Cells
        Calculates the aspect (direction of slope) for each cell of a raster. Aspect is measured in degrees from 0 to 360, clockwise from north.  |
        Creates individual points or polygons for each cell in a raster, optionally extracting band values as z coordinates or attributes.  |
        Evaluates basic arithmetic , minimum, maximum or average operations on the cell values of a pair of rasters.  |
        Replaces a range of band values in a raster with a new single value.  |
        Rounds off raster cell values.  |
        Partitions a raster image into arbitrarily sized groups of cells from the input image based on intensity differences in the input raster image cells.  |
        Performs basic arithmetic operations on the cell values of a raster against a numeric value.  |
        Calculates the slope (maximum rate of change in z) for each cell of a raster.  |
Working with Palettes
        Creates a palette from an attribute, and adds this palette to all selected bands on a raster.  |
        Creates a string representation of an existing palette on a raster and saves it to an attribute.  |
        Generates a palette out of the selected band(s) of a raster. The output raster will have the selected band(s) replaced by a new band with a palette.  |
        Alters the interpretation type of raster palettes.  |
        Identifies the palette key that matches a raster band’s Nodata value, and sets a value on it.  |
        Removes selected palette(s) from raster features.  |
        Resolves the palette(s) on a raster by replacing cell values with their corresponding palette values. Palette values with multiple components, such as RGB, are broken down and the individual values assigned to multiple, newly-added bands.  |
Workflow Control
        Forces accumulated raster operations to be processed, saving the state to disk and releasing resources to tune performance or assist with memory limitations.  |
        Reads raster features for testing purposes, including any accumulated raster operations. No additional operations are performed, and nothing is done with the features.  |
        Serializes the geometry of a raster feature into a Blob attribute, encoding the contents according to a choice of common binary raster formats.  |
        Creates a numeric raster of specified size and resolution, with default cell values.  |
        Decodes a binary attribute containing encoded rasters stored as Blobs, replacing the feature’s geometry with the decoded raster.  |
        Creates a color raster feature of specified size, resolution, and interpretation type, with default cell values.  |
        Selects specific bands and palettes of a raster for subsequent transformer operations.  |
Vectors and Rasters
        Creates a raster representation of vector or point cloud input features, using the fme_color attribute over a solid background fill for vector features. Point clouds may be rendered using their color or intensity components.  |
        Creates a numeric raster representation of vector or point cloud input features, where cell values are taken from the z coordinates of the input features and overlaid on a uniform background.  |
        Generates a raster from input vector and raster features, with fine control over symbolization and labeling, using the Mapnik toolkit.  |
        Sets point cloud component values by overlaying a point cloud on a raster. The component values for each point are interpolated from band values at the point location.  |
        Extracts the band and palette values from a raster at the location of one or more input points and sets them as attributes on the feature.  |
        Produces a raster digital elevation model (DEM) by uniformly sampling a Delaunay triangulation generated from input points and breaklines.  |
        Rasterizes vector or point cloud features onto an existing raster. For vector features the fme_color attribute sets pixel color, and point clouds may be rendered using their color or intensity components.  |
Raster features with GCP point values and coordinate system added as attributes.
        Special Characters  |
Dialog Options - Tables
 Cut, copy, and paste may be used within a transformer, or between transformers.  |
        Generally resets the table to its initial state, and may provide additional options to remove invalid entries. Behavior varies between transformers.  |
                                                             Processing Behavior  |
                                                             Feature Holding  |
                                                             No  |
Search for all results about the RasterGCPExtractor on the FME Community.
Contains information licensed under the Open Government Licence – Canada.
