RasterDEMGenerator
Produces a raster digital elevation model (DEM) by uniformly sampling a Delaunay triangulation generated from input points and breaklines.
- Creating raster elevation models from non-gridded features such as contours or point clouds.
The RasterDEMGenerator receives input features, triangulates a surface based on them, and then outputs a raster DEM with elevation values sampled from the surface at a specified regular interval. The output raster will contain a single numeric band, of the interpretation type Real64.
The input features are discarded.
Input features can be of a variety of types, including points, lines, areas, rasters, and point clouds. Aggregate geometries are supported, and multiple input features and types may be combined to produce one raster DEM output feature.
There are two input ports - Points/Lines and Breaklines. At least one input feature must be provided, which may be routed into either of these ports.
Input features may be either 2D or 3D - however, 2D features will be forced to 3D with an elevation (z value) of zero (0). If the source dataset’s z values are not stored as z coordinates (for example, contours with elevation stored as an attribute), a 3DForcer transformer may be used to convert them to a z coordinate prior to entering the RasterDEMGenerator.
A choice of interpolation methods is available. Surface tolerance and cell spacing may be adjusted, and a Nodata value may be defined.
In this example, we will generate a DEM from a set of contour lines, spaced at a ten meter interval. Note that the source data does not have elevation values as a z coordinate - though it is a 3D dataset, the z values are all zero (0).
The elevation values are stored as an attribute named ELEVATION and need to be applied as z values before the DEM is generated.
The contours are routed first into a 3DForcer, and then to the RasterDEMGenerator.
In the 3DForcer parameters dialog, Elevation is set to the ELEVATION attribute, and Preserve Existing Z Values is set to No. The attribute values will overwrite the existing z values.
Next, in the RasterDEMGenerator’s parameters dialog, we set Surface Tolerance to zero (0), which means that no vertex filtering will take place, and all points will be considered.
Cell Spacing (both X and Y) is set to 10. The output cells will be 10 meters square, as the source data’s coordinate system is in meters.
The default Interpolation Method and Nodata Value are left as is.
The output DEM raster has a single Real64 band, 10 meter square cells, and the specified Nodata value.
- If input features’ elevation values are not stored as Z coordinates, use a 3DForcer prior to the RasterDEMGenerator.
- To produce individual elevation points instead of a raster, consider using the DEMGenerator.
To build a TIN (triangulated irregular network) surface from points, lines, and/or rasters, see the TINGenerator and SurfaceModeller.
- When processing large input datasets, increasing the Surface Tolerance may provide performance gains, but may reduce accuracy.
- For more complex elevation modelling tasks, such as including contour generation, accessing components of the underlying surface model, feature draping, or creating multiple representations of a surface model, consider using the SurfaceModeller.
Choosing a Raster Transformer
Working with Rasters
Enhances the features of a raster image. The RasterSharpener enhances the borders, lines, and curves while reducing noise in the flat areas of the raster image. |
Working with Bands
Working with Cells
Working with Palettes
Workflow Control
Vectors and Rasters
These input features may be 2D or 3D. Other than points, lines and area geometries, they may also be raster, point cloud, and aggregate geometries.
2D features will be forced to 3D by adding a z value of 0. In most cases, all points extracted from this port will be found in the vertex pool of the underlying surface model. A minimum of 3 unique points are required to construct a surface model. Points with duplicate x and y values will be dropped.
These input features may be 2D or 3D, and may reside inside an aggregate structure.
2D features will be forced to 3D by adding a z value of 0. Breakline edges will be found in the edge pool of the underlying surface model. Sometimes, a breakline edge will be split up to allow an optimal triangulation of the surface model. Points with duplicate x and y values will be dropped.
This output port samples the underlying surface model according to the sampling rates specified in Output DEM X Cell Spacing, and Output DEM Y Cell Spacing, and produces a single raster feature consisting of evenly spaced 3D points arranged by rows and columns.
Invalid input features will be routed to the <Rejected> port.
INVALID_POINT_GEOMETRY_VERTICES
INVALID_BREAKLINES_GEOMETRY_VERTICES
INVALID_GEOMETRY_VERTICES
INVALID_POINTS_GEOMETRY_RASTER_NUM_BANDS
INVALID_POINTS_GEOMETRY_RASTER_NUM_PALETTES
INVALID_GEOMETRY_DIMENSION
Group By |
This parameter allows groups to be formed by attribute values. Zero or more attributes may be specified. Input features with the same attribute values are placed into the same group. The transformer then operates independently on each group of input features. If this parameter is left blank, the transformer will treat the entire set of input features as one group. |
Complete Groups |
Surface Tolerance |
This parameter is used to determine which input points to add to the surface model as vertices. Specifying a value of 0 turns off vertex filtering. Tip: A larger value will speed up surface model construction. The larger the value, the more input points will be filtered out. For input files with millions – or even billions – of points, it becomes essential to increase this value. When a positive value for surface tolerance is specified, it works as follows. For each vertex that is being added to the model:
Interpolation Method |
This parameter is used for the output ports DEMPoints and DEMRaster when these output ports exist on the transformer. It is also used if DrapeFeatures are input to the model.
These parameters specify the x and y sampling intervals for the output DEMPoints. |
Output DEM Raster Nodata Value |
This parameter is used only when Interpolation Method is set to PLANAR, and it only affects the output port DEMRaster. All output raster cells that fall outside the underlying surface model’s boundaries will be assigned the value of this parameter. When this parameter is blank, it is interpreted as NaN (Not a Number). Note: To ensure consistent raster output, it is highly recommended that you do not leave this parameter blank. |
Dialog Options - Tables
Yes |
| Aliases | DEMGridGenerator |
| History | This transformer was previously named DEMGridGenerator. |
Search for all results about the RasterDEMGenerator on the FME Community.
