Affiner
Performs an affine transformation (such as offset, rotate, or scale) on the coordinates of the feature.
Moving, scaling, and rotating 2D geometry.
The Affiner receives features with any geometry type and moves their x and y coordinates according to a specified affine transformation.
An affine transformation is a mathematical method of modifying geometry that:
Preserves lines/collinearity: all points on a straight line are still on a straight line after transformation.
Preserves parallelism: lines that are initially parallel are still parallel after transformation.
May not preserve angles, lengths, or areas, depending on the type of transformation performed.
Scaling, mirroring, rotating, shearing, and translating (relocating or offsetting) are all affine transformations. They can be performed singly or in combination.
The Affiner performs 2D transformations, using this formula:
x' = Ax + By + C
y' = Dx + Ey + F
Where (x,y) are the input coordinates and (x',y') are the transformed output coordinates.
Description |
Formula/Coefficients |
Example* |
Translate |
Move the geometry a fixed distance. |
x' = 1x + 0y + C y' = 0x + 1y + FSimplified: x' = x + Cy' = y + F C = horizontal (x) offset |
x' = 1x + 0y + 5
Scale |
Shrink or enlarge the geometry.
x' = Ax + 0y + 0 Simplified: x' = Ax A = horizontal (x) scale factor |
x' = 1.5x + 0y + 0
Rotate |
Rotate the geometry around the origin.
x' = cos(ϴ)x + −sin(ϴ)y + 0 Simplified: x' = cos(ϴ)x − sin(ϴ)y ϴ = Angle in degrees A = cos(ϴ) |
Rotate 30 degrees: x' = 0.866025x + -0.5y + 0
Shear |
Offset geometry in proportion to its x and y coordinates. |
x' = 1x + By + 0 Simplified: x' = x + By |
x' = 1x + 1.25y + 0
* Note these examples use geometry with an origin of 0,0 at the lower left corner of the polygon.
Geographic Features and Affine Transformations
The origin (0,0) of geographic features is generally at a distance from the geometry itself, and so affine transformations can produce large location shifts, in particular when scaling or rotating.
In this example, we will perform various transformations on a set of neighborhood polygon features, which are in a UTM projection with ground units in meters.
The features are routed into an Affiner.
Translating Features East and North
In the parameters dialog, we enter coefficients to move the features 500 meters east and 1000 meters north.
x' = 1x + 0y + 500
y' = 0x + 1y + 1000
The output features have been translated.
Scaling Features
In the parameters dialog, we enter the coefficients to scale the features up by a factor of 1.006.
x' = 1.006x + 0y + 0
y' = 0x + 1.006y + 0
Note that even a small scale factor such as this can produce large shifts in position when the features are georeferenced.
Rotating Features
In the parameters dialog, we enter the coefficients to rotate the features by 0.9 degrees.
We could enter explicit parameter values, but will use expressions to calculate the coefficients.
Note that the math functions @cos() and @sin() expect radians (not degrees), and so we add the @degToRad() function to convert our rotation angle to radians.
x' = cos(0.9)x + -sin(0.9)y + 0
y' = sin(0.9)x + cos(0.9)y + 0
Note that even a small rotation such as this can produce large shifts in position when the features are georeferenced, as they are being rotated about their origin (0,0) which is at a distance.
To perform affine transformations in place on geographic features, consider temporary reprojection (Reprojector) to a local coordinate system or using the CommonLocalReprojector.
The Scaler performs 2D and 3D scaling affine transformations, with additional options for specific geometry types and origin handling.
The Offsetter performs 2D and 3D translation affine transformations, with additional coordinate space options (polar and spherical coordinates, in addition to cartesian).
The Rotator and 3DRotator perform rotation affine transformations, with a simplified interface for rotation value, origin (2D) and axis choice (3D).
This transformer accepts all features. Arcs and ellipses are preserved.
Features transformed according to parameter selections.
The dynamic <Rejected> port appears when a parameter is set to a non-literal value that might make processing impossible.
For example, if a numeric parameter such as Line Width, Count Start, or Decimal Places is set to an expression, attribute value, or user parameter, it is possible to pass in a non-numeric value that cannot be used. Decimal Places = Cat cannot be processed, so the feature will be output via this port.
Rejected features will have an fme_rejection_code attribute explaining the reason for rejection.
A |
Provide values for all coefficients and constants in the affine formula: x' = Ax + By + C
Where (x,y) are the input coordinates and (x',y') are the transformed output coordinates. If a value is not needed for the required transformation, the value should be zero (0). |
Dialog Options - Tables
Search for all results about the Affiner on the FME Community.
