The Job Submitter service accepts and runs workspace job requests.
The Job Submitter service works with any workspace.
This service is requested using a URL or a form. For example,
http://Host/fmejobsubmitter/Repository/workspace.fmw?parameters
The resulting web page indicates whether the job submission was successful. If the job was submitted successfully, the FME Server transformation results are shown.
Alternatively, the job submitter service can be run from the Web User Interface.
Service Specific Request Parameters
| Name | Value | Description |
| opt_responseformat | xml | json | The language of the response. The text must be all lowercase. |
| opt_geturl | The URL to a dataset | The URL of the source dataset to be used for transformation. |
| opt_showresult | true | false | Whether the XML/JSON responses include the FME transformation result. The default value is true if this parameter is not present. |
| opt_servicemode | sync | async | Toggles between synchronous and asynchronous modes of the service. When jobs are submitted asynchronously (async), the response of submission success or failure is returned immediately. When set to synchronous (sync), the response is not returned until the job completes. |
| opt_requesteremail | comma-separated email addresses | Addresses to which notification email messages are sent. |
Job Directives and Notification Directives
This service supports Job Directives and Notification Directives.
 Job Directive Example
                                                This example specifies job queue high:
http://localhost/fmejobsubmitter/Samples/austinDownload.fmw&tm_tag=high
 Notification Directive Example
                                                Specifying the Notification Service topic to notify when a job succeeds or fails, respectively.
http://localhost/fmejobsubmitter/Samples/austinDownload.fmw?&nm_jobsuccess_topic=JOBSUBMITTER_ASYNC_JOB_SUCCESS&nm_jobfailure_topic=JOBSUBMITTER_ASYNC_JOB_FAILURE
Using Remote Data During a Request
Using data from HTTP POST body as Reader dataset
This web service can receive data and override source dataset via HTTP POST. The content of the POST request body will be saved to a temporary file which will be used as the Reader dataset of the workspace. If there is more than one reader in the workspace, then you will need to indicate which reader will use the temporary file. You indicate your choice when publishing the workspace by editing the service registration.
Using data from HTTP GET as Reader dataset
This web service can receive data and override Reader dataset via HTTP GET. The dataset should be specified as a URL and passed to service by 'opt_geturl' parameter. Both HTTP and FTP URLs are supported. If there is more than one reader in the workspace, then you will need to indicate which reader will use the temporary file. You indicate your choice when publishing the workspace by editing the service registration.
For example here is a service request that uses a remote KMZ dataset:
Response Elements
If the response format is specified as XML or JSON, a service response may contain the elements shown in the following table.
| Element | Child Elements | Value | Description |
| statusInfo | message | message string | service failure message |
| status | success | failure | service status | |
| mode | sync | async | service mode | |
| fmeTransformationResult | fmeServerResponse | FME Server response properties | FME Server response |
| fmeEngineResponse | FME Engine response properties | FME Engine response | |
|  | none | Email addresses | Requesters’ email addresses |
| jobID | none | job ID | The current job identifier |
Enabling E-Mail Notifications
The job submitter service can send email messages to notify you when a job completes successfully or unsucessfully.
For more information, see Configuring FME Server to Send Email Notifications.
See Also
