You can perform the following from the Run Workspace page:
- Run or Share a Workspace
- Repository: The repository that holds the workspace you want to run.
- Workspace: The workspace you want to run.
- Service: An FME Server service that the workspace is registered to run.
- Email results to (optional): An email address to deliver results. This option allows you to receive email notification when the translation is complete, rather than wait for a completion message on this page.
- Published Parameters: Provide any published parameters or other settings specific to the FME Server service.
- Advanced:
- Job Queue (optional): The queue in which to run the job. The specified queue overrides the queue that would otherwise be assigned based on Queue Control job routing rules. If not specified, job routing rules apply. To view the queues to which FME Engines are assigned, open the Engines page.
- Queued Job Expiry Time (optional): The length of time after which a job that is waiting in queue does not execute. If the job does not execute before this time is reached, it remains in the queue until it is ready to execute, but execution is not attempted. This directive is useful for time-sensitive jobs that you do not want to run after the specified time is exceeded.
- Running Job Expiry Time (optional): The time a job will remain in the running state. This directive is used to ensure that a job does not hang and block an FME Engine indefinitely. The minimum allowable value is 1.
- FME Server App: A URL that runs the workspace as an "app" from a browser, and allows users to configure any published parameters.
- Webhook URL: A URL that can be integrated with third-party software to run the workspace.
- Click Create a Webhook or Workspace Actions > Create Webhook. The Create Webhook page opens.
- If required, edit the Token Name, Description, and Expiration of the token.
- User Can Upload: If the workspace uses the Data Upload Service, this setting allows users to upload temporary files that are used to run the workspace.
- Parameters: Configure any published parameters with the values you want the workspace to run when the webhook is invoked.
-  Click OK. The webhook is created and URLs are provided for Authorization Header and Query String Authorization. Click the Copy icons to copy either or both URLs.Note: You can access the token that was created for these URLs, and view the permissions for it, on the API Tokens tab of the Token Management page. To download all of the information about this webhook, including token ID, URLs, and header values, click Download. WARNING: This is your only opportunity to download complete webhook metadata. After navigating away from this page, it is no longer available.
- Click Run or Workspace Actions > Run Workspace. You may see an intermediate page indicating that processing has begun.
- Edit Workspace Services
- never: Disregard changes in the camera view
- onStop: Refresh the link n seconds after camera movement stops, where n is specified by View Refresh Time.
- onRequest: Refresh the link only when explicitly requested in Google Earth.
- onRegion: Refresh the link when the Region becomes active.
- onChange: Refresh when the KMZ file is loaded and whenever the Link parameters change.
- onInterval: Refresh every n seconds, where n is specified by View Refresh Interval.
- onExpire: Refresh when the expiration time is reached. If a fetched file has a NetworkLinkControl, the <expires> time takes precedence over expiration times specified in HTTP headers. If no <expires> time is specified, the HTTP max-age header is used, if present. If max-age is not present, the Expires HTTP header is used, if present.
- Download or View a Workspace
 Expand for instructions
                                                        You can run a workspace directly from this page, or share a workspace as an "app" that is run from a browser, or as a webhook that is integrated with third-party software.
Note: Workspace templates cannot be run from FME Server.
Note: To edit the FME Server services for a workspace, select Workspace Actions > Edit Services. For more information, see Edit Workspace Services (below).
Note: To receive email, the following FME Server email subscribers must be properly configured: DataDownload_Email_JobFailure, DataDownload_Email_JobSucess, JobSubmitter_Email_JobFailure, JobSubmitter_Email_JobSuccess. For more information, see Monitoring FME Server Events from Topics.
If any published parameters represent data files, this page allows you to upload files to FME Server, making use of the Data Upload Service behind the scenes. This service works in conjunction with the Data Download, Data Streaming, and Job Submitter services to upload files.
If any parameters were published to FME Server as type Geometry, click the corresponding map icon to open an interface for specifying the desired geometry. For more information, see Using the Geometry Parameter in FME Server.
Note: Any "Feature Types to Read" published parameters that contain spaces must be enclosed in double quotes. For example, "Bus Routes".
Note: Resources connections to Amazon Web Services (AWS) S3 buckets cannot be accessed.
Other Ways to Run this Workspace
(Optional) You can generate a security token for the workspace, along with URLs that use the token. These URLs allow unauthenticated access to run the workspace in the following ways:
To create an app URL, click Create an FME Server App or Workspace Actions > Create Server App, and complete the settings on the Workspace Apps page.
        To update the published parameters, click Change Parameters, update as required, and click Create a Webhook to generate a new webhook.
To return to the Run Workspace page, click Run Workspace on the breadcrumb at top.
Topics to Notify
Displays the Notification Service topics that are notified on success or failure of running the workspace, by registered service. For more information, see Monitoring FME Server Events from Topics.
Displays details of any published parameters.
The resulting web page indicates whether the job submission was successful.
                                                        You can configure the FME Server Web Services that a workspace is registered to run. Select Workspace Actions > Edit Services.
 Data Download, Data Streaming, and Job Submitter Properties
        Send HTTP Message Body to Reader
The reader feature type that receives HTTP content, in place of the actual dataset.
Note: This field does not specify the flow of notification data.
Include Writers in Download/Stream
The writer for outputting data after the workspace runs. If the workspace includes multiple writers, you may want to change the writer selected by default to one that is better configured for downloading or streaming data.
For example, consider a workspace with two writers. One writer inserts a single timestamp record into an Oracle table each time the workspace is run. The other writer supports downloading all of the data users want in AutoCAD. In this case, you will likely specify the AutoCAD writer as the desired output writer.
 KML Network Link Properties
        Network Link Name
Specify a name for the KML Network Link.
Visibility
If 1, features are drawn in the Google Earth 3D viewer. Otherwise, specify 0.
Network Link Description
Provide a description for the KML Network Link.
View Refresh Mode
Specifies how the KML Network Link is refreshed when the Google Earth Camera view (that is, the viewer's location in space) changes.
View Refresh Time
If View Refresh Mode is onStop, specifies the number of seconds to wait before refreshing the view.
View Format
The format of the query string that is appended to the Link's <href> tag before the file is fetched.
Refresh Mode
Specifies a time-based refresh mode.
If Refresh Mode is onInterval, specifies the number of seconds to wait before refreshing the view.
North, South
Specifies the latitude of the north and south edge of the bounding box, in decimal degrees from 0 to ±90.
East, West
Specifies the longitude of the east and west edge of the bounding box, in decimal degrees from 0 to ±180. (For overlays that overlap the meridian of 180° longitude, values can extend beyond that range.)
Minimum Level of Detail Pixels
Defines a square in screen space, with sides of the specified value in pixels. For example, 128 defines a square of 128 x 128 pixels. The region's bounding box must be larger than this square, and smaller than Maximum Level of Detail Pixels, in order for the Region to be active.
Measurement in screen pixels that represents the maximum limit of the visibility range for a given Region. A value of −1 indicates "active to infinite size."
Expand for instructionsSelect Workspace Actions > Download Workspace or View Workspace.
See Also
