FME Server Ports
The following ports are used by the FME Server Core, unless specified otherwise:
Port Description
25 (Windows), 7125 (Linux) SMTP Publisher (unsecured).
80 Automatic (online) Licensing requests.
465 SMTP Publisher (secured).
6379 FME Server Queue, for managing Queue Control.
7069 Database Connections and Web Connections requests.
7070 FME Engines register on this port initially, after which they are assigned a dedicated port for communication.
7071 Jobs, Projects, Workspaces, Licensing, and User Management requests.
7072 Automations external actions and Notification Service subscriber requests.
7073 Schedules requests.
7074 Automations external actions and Notification Service subscribers register on this port initially, after which they are assigned a dedicated port for communication.
7075 Automations triggers and Notification Service publisher requests.
7076 Automations triggers and Notification Service publishers register on this port initially, after which they are assigned a dedicated port for communication.
7077 FME Server configuration and Backup & Restore requests.
7078 WebSocket Server requests.
7079 Resources requests.
7081 System Cleanup requests.
7082 Private port used by the PostgreSQL database server that hosts the FME Server Database on an Express installation.
7500 Manage FME Server Core processes.
7501 Manage FME Engines processes, cancel FME Engines, and add/remove FME Engines.
