AttributeFileWriter
Writes the contents of an attribute to a text or binary file.
Jump to Configuration
  • Writing files mid-workspace that contain the value of an attribute
  • Replacing a writer where the desired content is stored as an attribute
  • Writing images that have been stored as blob attributes
  • Writing coordinate system information to a file
  • Writing text lists of attribute values
The AttributeFileWriter receives any type of feature and writes the contents (value) of a specified attribute to an external file.
A Target Filename and encoding type must be specified. File names may be provided explicitly or by attribute value, expression, user parameter, or conditional value. If a target file already exists, it may be overwritten or appended to.
The attribute value and target file may be text or binary. A variety of encoding choices are available for text files. Binary files should be designated as Binary (fme-binary), as the transformer writes it as-is and will simply preserve the attribute contents as a Blob.
  • When writing any binary file types, ensure that Target File Encoding is set to Binary (fme-binary).
  • Full path names can be created from existing attribute values by using the Text Editor to create an expression.
  • The most common text encodings are Windows Latin-1 (windows-1252) and Unicode 8-bit (utf-8).
  • If you are unsure of the encoding used by the attribute, the Feature Information window in the FME Data Inspector will often help (see image in previous example)
Dialog Options - Tables
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases
History
Search for all results about the AttributeFileWriter on the FME Community.
