Tester
Evaluates one or more tests on a feature, and routes the feature according to the outcome of the test(s).
Jump to Configuration
  • Performing quality testing on data
  • Dividing features into two streams based on a test
  • Isolating a subset of features based on a test
The Tester accepts any feature. It evaluates each feature against one or more user-defined tests, and outputs the feature via the Passed port if it meets the defined conditions, or via the Failed port if it fails the defined conditions.
The tests are constructed as a series of Test Clauses, which evaluate values or expressions based on a wide range of available Operators and test types. The Test Clauses are connected with Logic - combinations of AND, OR, and NOT, with parentheses to define evaluation order.
Creating Test Clauses
Each clause is composed of a value to test, and the method of testing it. Depending on the type of test, at a minimum the clause will consist of a Left Value and an Operator. If the chosen Operator needs more information (for example, testing for an attribute that is greater than a certain value), a Right Value field is provided.
The Test Clauses are created in a table, and numbered from the top down.
Left Value
Operator
Right Value
Mode*
The value or expression to test The type of test to perform The value for comparison, if required by the operator Test the values in a specific manner
Latitude > 49.000001 Automatic
@Area() In Range (1,100) Numeric
SnackType Like Kebabs Case Sensitive
Traffic Attribute Is Null <Unused> Automatic
Count Type Is Integer Automatic
* Note that Mode is only available for individual tests when Comparison Mode is set to Specify Per Test.
Test Clause Operators
Cached Values and Data-Aware Test Clauses
If Feature Caching is enabled, valid attribute values from upstream features can be viewed to complete test clauses.
As shown here in the Tester, if the Left Value has been set to an Attribute Value and the features have been cached, the context menu provides access to the values available in those features. If there are only a few choices, they will be presented in a sub-menu.
If there are a large number of choices, the values will be presented in a Select Value dialog, where the values may be sorted and searched with the Filter option.
Connecting Test Clauses: Logic
Multiple test clauses are connected with Logic, using AND, OR, and NOT in addition to parentheses to specify how the tests are evaluated to determine passing or failing.
Logic connectors can be edited by selecting options in the Logic column of the Test Clauses table, or may be edited directly using the Composite Expression parameter’s Edit button.
  • Due to bulk mode processing, features may appear to output in chunks. Although feature order from a single output port remains intact, when chunks of features are output through both the Passed and Failed ports, unexpected results may occur in workspaces that rely on feature ordering from joined output ports. In these scenarios, we recommend that you do not upgrade the Tester to its 2019.1 or later version, or revise your workspaces so they do not rely on feature ordering from joined output ports. Feature ordering may be specified with the Advanced > Preserve Feature Order parameter.
  • If you have several Tester transformers in sequence, consider using the TestFilter instead. This transformer allows you to create a series of tests with named output ports for each result.
  • Note that testing operations are lexical comparisons and not locale-aware.
  • When filtering out a subset of features, consider the logic of the test(s) when choosing an output port. For example, to remove all of the Dog Parks from a list of parks, you could either:
    • Set DogParks=Y, and connect the Failed port (dropping the Passed features), or
    • Set DogParks=N, and connect the Passed port (dropping the Failed features).
Dialog Options - Tables
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies None
Aliases
History This transformer replaced the AttributeTester and GenericTester transformers.
Search for all results about the Tester on the FME Community.
