AttributeFileReader
Reads the contents of an external text or binary file and attaches it to a feature as the value of an attribute.
- Attaching files to features
- Adding file contents to features
- Reading geometry content stored in a separate file
The AttributeFileReader receives any type of feature and adds the contents of an external file to them, as the value of a new or existing attribute.
File selection may be done explicitly or by attribute value, expression, user parameter, or conditional value.
The file may be text or binary. (Text refers to the file type, rather than the file content - it may not necessarily be plain text.) A variety of encoding choices are available for text files. Binary files should be designated as Binary (fme-binary), as the transformer is not aware of formats and will simply preserve the file contents as a Blob.
- All types of binary files are stored as Blobs, and Source File Character Encoding should be set to Binary (fme-binary) .
- The most common text encodings are Windows Latin-1 (windows-1252) and Unicode 8-bit (utf-8).
- If a text file includes special characters, the appropriate Source File Character Encoding should be selected to preserve those characters.
- Full path names can be created from existing attribute values by using the Text Editor to create an expression.
- Some transformers (such as the XMLFlattener) can read external files, and so do not need to use an AttributeFileReader first.
Dialog Options - Tables
Dependencies | None |
Aliases | |
History |
Search for all results about the AttributeFileReader on the FME Community.
