RasterSelector
Selects specific bands and palettes of a raster for subsequent transformer operations.
- Isolating specific bands or palettes to perform operations on.
The RasterSelector receives raster features and designates specific bands and palettes as “selected.”
Once a selection is performed, transformers that support raster selection will only affect the selected bands and palettes. Unselected elements are passed through unaltered, and remain in an unselected state until another RasterSelector operation is performed.
The default state of a raster feature is that all bands and palettes are selected - that is, after reading in the raster, subsequent raster transformers will operate on all bands and palettes. Raster transformers may support both band and palette selection, band selection only, or may be unaffected by it. Check a transformer’s documentation for raster selection support details.
Bands and palettes are selected using the band and palette indices, specified in a string. The string may either be entered as a parameter or provided as an attribute.
Selection Strings
The format of the string is B:P (band number, then palette number, separated by a colon). If the raster does not have palettes, only band numbers should be specified.
- Indices are zero-based, so the first band or palette is at index 0.
- The keyword ALL can be used in place of band and palette numbers to select all bands or all palettes on a specific band.
- Multiple bands or band-palette pairs are separated by a semicolon (;).
- Multiple palettes on one band are separated by a comma (,).
Selection String Examples
All bands |
ALL: |
All bands and all palettes |
ALL:ALL |
First palette of the first band of a raster |
0:0 |
First palette of the first band and first palette of the third band |
0:0;2:0 |
First three bands of the raster (without palettes) |
0:;1:;2: |
First three bands of the raster (with their palettes) |
0:ALL;1:ALL;2:ALL |
First two palettes on the first band |
0:0,1 |
- It is possible to select bands without selecting the attached palettes.
- It is NOT possible to select palettes without selecting the owning band.
- Specific palettes cannot be selected on ALL bands; for example, ALL:2.
Selection String Syntax Change
As of FME 2021.2, the syntax used for band and palette selection strings is as documented above. Selection strings created with the previous format (as in previously-saved workspaces) are converted automatically.
The format of the string is B P (band number, then palette number, separated by a space). If the raster does not have palettes, only band numbers should be specified.
All bands |
ALL |
ALL ALL |
0 0 |
0 0;2 0 |
0;1;2 |
0 ALL;1 ALL;2 ALL |
0 0,1 |
In this example, we will remove the green band from an RGB raster. The original raster has three bands - red, green, and blue - and no palettes. Note the band index numbers, starting with zero (0). Green is Band 1.
The operation will take three steps (though the third is optional):
- Select the band to be removed.
- Remove the selected band.
- Perform another raster selection, to re-select the remaining bands for further processing (optional).
The raster is first routed into a RasterSelector. In the parameters dialog, Selection Mode is Band and Palette List.
The Band and Palette List is set to 1:, which will select the green band (Band 1) only.
Next, the raster passes through a RasterBandRemover. This transformer has no parameters to set, and removes all currently selected bands.
After exiting the RasterBandRemover, the raster feature has no bands selected, as the previously selected band no longer exists. Selection does not generally affect writers, but if further processing is required, the remaining bands need to be re-selected.
Another RasterSelector is added, and the Band and Palette List is set to ALL:, selecting all bands.
The output raster feature has only two bands - red and blue. Note that the band index numbering has been reset - Band 1 is now blue.
In this example, we will select a palette to be extracted into an attribute, using a RasterPaletteExtractor transformer. The source raster has one band, with two palettes - an RGB palette containing colors, and a string palette that contains labels. We are interested in the string palette.
Note that the only band is Band 0, and the string palette is Palette 1.
This operation will take two steps:
- Select the palette of interest, and the band it is on.
- Perform the extraction.
The Band and Palette List is set to 0:1, representing Band 0 and Palette 1, separated by a colon.
The next step is the RasterPaletteExtractor. In the parameters dialog, we set a name for a new attribute which will contain the contents of the selected palette, naming it _palette.
The output raster feature has a new attribute, with the contents of the selected palette.
Note that the state of the raster feature as it exits the RasterPaletteExtractor is still one band and one palette selected. If further processing was required, another RasterSelector may be needed to re-select all bands and palettes, as shown in the previous example.
A Band and Palette List of ALL:ALL will re-select all bands and palettes.
- This function overrides any existing selection on the raster. All unspecified bands and palettes on a raster after selection are treated as unselected for future operations.
- Selection is not considered by writers, so use the RasterBandSeparator and filtering to write subsets of the bands and palettes as individual features.
Choosing a Raster Transformer
Working with Rasters
| RasterConvolver |
| RasterRotationApplier |
Working with Bands
| RasterBandKeeper |
| RasterBandNodataRemover | Removes the existing Nodata identifier from selected bands of a raster feature. Any values previously equal to the Nodata value are considered valid data. |
| RasterBandNodataSetter | Sets a new Nodata value on selected bands of a raster feature. |
Working with Cells
| RasterAspectCalculator |
Working with Palettes
| RasterPaletteAdder |
| RasterPaletteNodataSetter |
Workflow Control
| RasterSelector |
Vectors and Rasters
| PointCloudOnRasterComponentSetter | Sets point cloud component values by overlaying a point cloud on a raster. The component values for each point are interpolated from band values at the point location. |
If a specific band or palette number is specified in the Band and Palette List parameter, that band or palette must exist on the input feature. If the specified band or palette number does not exist, an error will occur.
Raster features with specified bands and palettes in a selected state.
INVALID_RASTER_NO_BANDS
| Selection Mode |
Band and Palette List: To specify explicit bands and palettes in the Band and Palette List parameter. Attribute: A band and palette selection string will be provided in an attribute. |
| Band and Palette List | Enter a band and palette list string. |
| Attribute | Specify the attribute containing the band and palette list string. |
Dialog Options - Tables
| Aliases | RasterBandSelector, RasterPaletteSelector |
Search for all results about the RasterSelector on the FME Community.
