| abs(arg) |
Returns the absolute value of arg. |
| acos(arg) |
Returns the arc cosine of arg, in the range
[0,pi] radians. Arg should be in the range [-1,1]. |
| add(arg1,[arg2]...) |
Returns the sum of the arguments. |
| asin(arg) |
Returns the arc sine of arg, in the range
[-pi/2,pi/2] radians. Arg should be in the range [-1,1]. |
| atan(arg) |
Returns the arc tangent of arg, in the range
[-pi/2,pi/2] radians. |
| atan2(y,x) |
Returns the arc tangent of y/x, in the range
[-pi,pi] radians. x and y cannot both be 0. |
| average(arg1,[arg2]...) |
Accepts a list of numbers and finds the average.
Empty, missing, and null input values are ignored but other non-numeric data results in a
failure. If no inputs are provided, an empty string is returned. |
| ceil(arg,[decimal_places]) |
Returns the smallest value not less
than arg, to the specified decimal_places. If decimal_places is 0 or unspecified, a 64-bit integer is returned. If decimal_places is >0, a 64-bit floating-point value is returned. If arg is out of range, null is returned. |
| col() |
Returns the column of the raster cell being evaluated. |
| cos(arg) |
Returns the cosine of arg, measured in radians. |
| cosh(arg) |
Returns the hyperbolic cosine of arg. If
an overflow occurs, infinity is returned. |
| degToRad(arg) |
Converts degrees to radians. |
| div(x,y) |
Computes x/y. If division by zero occurs, infinity is returned. |
| double(arg) |
Returns arg in double precision. |
| exp(arg) |
Returns the exponential of arg, defined
as e to the power of arg. If an overflow occurs, infinity is returned. |
| floor(arg,[decimal_places]) |
Returns the largest value not greater
| fmod(x,y) |
Returns the floating-point remainder of
the division of x by y. The sign of the remainder follows the sign of x. If y is 0, NaN is returned. |
| hypot(x,y) |
Computes the length of the hypotenuse of
a right-angled triangle, that is, sqrt(x*x+y*y). |
| int(arg) |
If arg is in the range of a 64 bit integer, convert by truncation. If arg is out of range, null is returned. |
| int8(arg) |
If arg is in the range of a 8 bit integer, convert by rounding. If arg is out of range, null is returned. |
| int16(arg) |
If arg is in the range of a 16 bit integer, convert by rounding. If arg is out of range, null is returned. |
| int32(arg) |
If arg is in the range of a 32 bit integer, convert by rounding. If arg is out of range, null is returned. |
| int64(arg) |
If arg is in the range of a 64 bit integer, convert by rounding. If arg is out of range, null is returned. |
| isnodata(arg) |
Returns a value of 1 if arg is equal to the nodata value, and 0 otherwise. |
| log(arg) |
Returns the natural logarithm of arg. |
| log10(arg) |
Returns the base 10 logarithm of arg. |
| max(arg1,[arg2]...) |
Returns the largest argument. |
| min(arg1,[arg2]...) |
Returns the smallest argument. |
| mult(arg1,[arg2]...) |
Returns the multiplication of all the arguments. |
| pi() |
Returns the value of pi. |
| pow(x,y) |
Computes the value of x to the power
y. If x is negative, y is expected to be an integer value. If x is negative, and y is a floating-point value, NaN is returned. |
| radToDeg(arg) |
Converts radians to degrees. |
| rand() |
Returns a random value between 0 and 1. |
| real32(arg) |
If arg is in the range of a single precision float, return as a single precision float. If arg is NaN or infinity, or the negation thereof, cast as a single precision NaN or infinity. Otherwise, arg is beyond the range of a single precision float, so we return positive or negative infinity. |
| real64(arg) |
If arg is in the range of a double precision float, return as a double precision float. If arg is NaN or infinity, or the negation thereof, cast as a double precision NaN or infinity. Otherwise, arg is beyond the range of a double precision float, so we return positive or negative infinity. |
| round(arg,[decimal_places]) |
Returns the value nearest arg, to the specified decimal_places. If decimal_places is 0 or unspecified, a 64-bit integer is returned. If decimal_places is >0, a 64-bit floating-point value is returned. If arg is out of range, null is returned. |
| row() |
Returns the row of the raster cell being evaluated. |
| sin(arg) |
Returns the sine of arg, measured in radians. |
| sinh(arg) |
Returns the hyperbolic sine of arg. If an overflow occurs, infinity is returned. |
| sqrt(arg) |
Returns the square root of arg. If arg is negative, NaN is returned. |
| sub(x,y) |
Computes x-y. |
| sum(arg1,[arg2]...) |
| tan(arg) |
Returns the tangent of arg, measured in
radians. |
| tanh(arg) |
Returns the hyperbolic tangent of arg. |
| uint8(arg) |
If arg is in the range of a 8 bit unsigned integer, convert by rounding. If arg is out of range, null is returned. |
| uint16(arg) |
If arg is in the range of a 16 bit unsigned integer, convert by rounding. If arg is out of range, null is returned. |
| uint32(arg) |
If arg is in the range of a 32 bit unsigned integer, convert by rounding. If arg is out of range, null is returned. |
| uint64(arg) |
If arg is in the range of a 64 bit unsigned integer, convert by rounding. If arg is out of range, null is returned. |
