RasterMosaicker
Merges multiple raster features into a single raster feature.
- Merging multiple rasters
- Joining abutting raster tiles together into a single feature
- Merging overlapping raster features together, blending the overlaps
- Preparing data for use in operations that require a single raster feature (eg VectorOnRasterOverlayer)
The RasterMosaicker accepts a number of raster features and combines them into a single raster feature.
The input rasters must all have the same number of bands and palettes, or selected bands and palettes.
Each band is individually mosaicked together, and then appended to the output raster. The output raster will have the same number of bands and palettes as the input (whether whole rasters or selected bands/palettes).
If there are gaps in data (that is, areas not covered by any raster), the empty cells will be filled with Nodata values if available, or zero if not.
Bands and Palettes
Rasters may have one band or multiple bands.
Rasters may have no palette, one palette, or multiple palettes. For more information on raster structure, see Rasters (IFMERaster).
Selecting Raster Bands and Palettes
To select specific bands and/or palettes, use the RasterSelector prior to the RasterMosaicker.
- When there are no selected palettes or Merge Palettes is No, each band in a set must have the same band interpretation and Nodata value.
- When there are selected palettes and Merge Palettes is Yes, each band must have one selected palette, and all palettes must have the same value interpretation.
A variety of options are available for handling alignment issues, overlapping pixel values, Nodata values, and differing resolution.
Attributes from the input features may be merged onto the output raster, and an optional Count attribute will record the number of input features included.
Attributes from the input features may also be appended to an optional list attribute.
In this example, we start with a set of three individual georeferenced images.
The features are routed into a RasterMosaicker.
The default settings will provide the desired results. We will also add a Combined Count attribute - Count - to track how many images have gone into the mosaicked image, and create a list attribute called Basenames which will contain the name of each source image.
One single raster feature is output. In the Data Inspector, we can see the new list attribute and count, indicating that three rasters went into the mosaic, and what their names were.
Choosing a Raster Transformer
Working with Rasters
| RasterConvolver |
| RasterRotationApplier |
Working with Bands
| RasterBandKeeper |
| RasterBandNodataRemover | Removes the existing Nodata identifier from selected bands of a raster feature. Any values previously equal to the Nodata value are considered valid data. |
| RasterBandNodataSetter | Sets a new Nodata value on selected bands of a raster feature. |
Working with Cells
| RasterAspectCalculator |
Working with Palettes
| RasterPaletteAdder |
| RasterPaletteNodataSetter |
Workflow Control
| RasterSelector |
Vectors and Rasters
| PointCloudOnRasterComponentSetter | Sets point cloud component values by overlaying a point cloud on a raster. The component values for each point are interpolated from band values at the point location. |
One mosaicked raster feature, or one mosaicked raster feature per group if Group By is used.
Non-raster features will be routed to the <Rejected> port, as well as rasters with elements not compatible with the current mosaicking operation.
EXTRA_RASTER_TOO_MANY_PALETTES
INVALID_RASTER_MISMATCHED_NODATA_VALUE
INVALID_RASTER_PALETTE
INVALID_RASTER_BANDS
| Group By | The rasters may be organized into groups with the Group By parameter, with each group of rasters having its own output raster. |
| Complete Groups |
| Snapping Type |
Used if the rasters are not perfectly aligned. The first input feature defines the reference grid. Resample: Resamples (if necessary) subsequent raster features to fit the reference grid. Offset: Moves (if necessary) subsequent raster features to fit the reference grid, without resampling. Offsetting may be faster than resampling, but requires that all rasters have the same pixel size. |
| Interpolation Type |
If the input rasters do not line up exactly or if they have different spacings, this transformer will use the selected Interpolation Type to snap and/or resample the input rasters according to the selected method:
| Overlapping Values |
Specifies how output cell values will be calculated when rasters overlap.
| Nodata Overwrites Data |
When Overlapping Values is set to Last, this option specifies whether Nodata values should overwrite data values in rasters that have been previously drawn. Yes: any Nodata overlapping real data values will overwrite the real data values. No: Nodata overlapping real data will be ignored, and the real data values will be preserved. Note that data values will always overwrite both Nodata and data values. |
| Merge Palettes |
Specifies how palettes will be treated when present. Yes: Selected palettes in each input band set will be merged to create a single palette for the output band. No: Selected palettes in each input band set will be accumulated on the output band without modification. |
| Accumulation Mode |
Drop Incoming Attributes: Attributes from all incoming features are removed, including the first feature. Merge Incoming Attributes: Attributes from incoming features are merged onto the output raster feature. Use Attributes from One Feature: Attributes from the first input raster feature are retained. |
Generate List
When enabled, adds a list attribute to the output raster feature, retaining attribute values for each input feature.
| List Name |
Enter a name for the list attribute. Note: List attributes are not accessible from the output schema in Workbench unless they are first processed using a transformer that operates on them, such as ListExploder or ListConcatenator. Alternatively, AttributeExposer can be used. |
| Add To List |
All Attributes: All attributes will be added to the output raster feature. Selected Attributes: Enables the Selected Attributes parameter, where specific attributes may be chosen to be added. |
| Selected Attributes | Enabled when Add To List is set to Selected Attributes. Specify the attributes you wish to be added. |
| Combined Count | Name the attribute to contain the number of features that were combined to create the raster feature. |
Dialog Options - Tables
Yes |
Search for all results about the RasterMosaicker on the FME Community.
