RasterObjectDetectorSamplePreparer
Aids in preparation of positive and negative samples provided by the user to be used by the RasterObjectDetectionModelTrainer.
A hand-picked selection of positive samples is used in the preparation step of creating a custom detection model.
This is the suggested way of preparing samples to be supplied to the RasterObjectDetectionModelTrainer for custom detection model creation. Hand-picking good quality positive samples yields a higher accuracy detection model, compared to artificially generated samples.
The transformer accepts any feature but all contents (except parameters) will be ignored and preserved with the output feature.
The Output port returns the original feature and the following attributes:
- _out_bg_desc_fname: Path to the background description file
- _out_num_negative_samples: Number of negative samples in the background description file
- _out_vec_fname: Path to the .vec file which will contain the positive samples
- _out_num_positive_samples: Number of positive samples in the .vec file
This port returns a feature with all its original contents and an fme_rejection_message containing the error message if any occur.
For both positive and negative sample directories, we advise to collect your images into a single directory (one for positive, and another for negatives). If you have a "working directory" where you want your project files to reside, a sub-directory there containing your negative samples is a suggested location (but it can be anywhere).
Training a detection model requires a set of negative or background images that do not contain the object you are trying to detect. Depending on the application, you may get away with using random images. However, if your object(s) have a very specific background, you may want to take the positive samples and crop out the object to get some samples that do not contain your object.
Source Directory |
Directory containing negative sample images. For best operation, make sure the names do not contain spaces or special characters. |
Operation Mode |
A very good positive sample set is a key to a high quality detection model. This might be a time consuming process but it is best to find your object in its natural setting (where you will be detecting it). For instance, if you are planning to detect cars at a certain intersection, images of that intersection will work best. You will also need to annotate the images manually or using opencv_annotate tool, which can be found in [FME_HOME]/plugins/opencv/. You can read more about how to use the tool here. Follow the instructions on how to annotate your samples. In short, call opencv_annotation --annotations={path/to/output/annotations/file.txt} --images={/path/to/positive/samples/dir}. There are also two optional parameters: --maxWindowHeight [maximum image height to resize in case they are too tall] --resizeFactor [factor to resize the image by if it's too tall]
The produced .txt file can be supplied to the Annotation File parameter. The annotation file should contain one line per each annotated image in the format: [path to image] [number of annotations] [x1_1] [y1_1] [width_1] [height_1] ... [x1_n] [y1_n] [width_n] [height_n]
Annotation File |
Positive annotation file produced manually or by calling opencv_annotation. |
Number of Samples |
Number of positive samples contained in the annotation file. |
Width and Height |
Width and Height of the detection window of the resulting detection model. Determines the minimum size of the object that the model will be able to detect. |
Background Description File |
Path to the output background description file. We recommend outputting this file in the subdirectory that contains your directory with negative samples. This file can be input into the RasterObjectDetectionModelTrainer using the Background Description File parameter. |
Prepared Positives File |
Output file containing the prepared positive samples. This file can be input into RasterObjectDetectionModelTrainer using the Positive Samples File parameter. |
Dialog Options - Tables
