RasterObjectDetectorSampleGenerator
Aids in generation and preparation of positive and negative samples to be used by the RasterObjectDetectionModelTrainer.
RasterObjectDetectorSampleGenerator requires a single positive image of the object you are attempting to detect and will artificially generate a large number of samples by morphing the image source. We do not recommend this method for most users, since many times, a smaller number (for example, 100) of carefully hand-picked positive samples can result in a better detection model than a larger number (for example, 1000) of artificially generated. Therefore, to get better results we recommend RasterObjectDetectorSamplePreparer.
The transformer accepts any feature but all contents (except parameters) will be ignored and preserved with the output feature.
The Output port returns the original feature and the following attributes:
- _out_bg_desc_fname: Path to the background description file
- _out_num_negative_samples: Number of negative samples in the background description file
- _out_vec_fname: Path to the .vec file which will contain the positive samples
- _out_num_positive_samples: Number of positive samples in the .vec file
This port returns a feature with all its original contents and an fme_rejection_message containing the error message if any occur.
Training a detection model requires a set of negative or background images that do not contain the object you are trying to detect. Depending on the application, you may get away with using random images. However, if your object(s) have a very specific background, you may want to take the positive samples (if you have any) and crop out the object to get some samples that do not contain your object.
Source Directory |
Directory containing negative sample images. For best operation, make sure the names do not contain spaces or special characters. |
Operation Mode |
Source Image |
Single image source that will be morphed to generate samples. The source should only contain your image. Image will be overlayed on top of the provided negative samples, twisted, rotated and have its colors tweaked. Those parameters can be tweaked in the Advanced settings. |
Number of Samples |
Number of artificial samples to be generated. |
Width and Height |
Width and Height of the detection window of the resulting detection model. Determines the minimum size of the object that the model will be able to detect. |
Background Description File |
Path to the output background description file. We recommend outputting this file in the subdirectory that contains your directory with negative samples. This file can be input into the RasterObjectDetectionModelTrainer using the Background Description File parameter. |
Prepared Positives File |
Output file containing the prepared positive samples. This file can be input into RasterObjectDetectionModelTrainer using the Positive Samples File parameter. |
Starting Transparency Value |
Background color that denotes transparent color. Since there might be compression artifacts, the amount of color tolerance can be specified by the Transparency Threshold parameter. |
Transparency Threshold |
All pixels within the following range: from (Starting Transparency Value - Transparency Threshold) to (Starting Transparency Value + Transparency Threshold) are interpreted as transparent. |
Invert Colors |
If the parameter is set to Yes, colors will be inverted. |
Invert Randomly |
If the parameter is set to Yes, colors will be inverted randomly. |
Maximum Intensity Deviation |
Maximum intensity deviation of pixels in foreground samples. |
Maximum Rotation Angles |
Maximum rotation angle towards X, Y and Z axis specified in radians. |
Maximum Sample Scale |
When specified, the source image will not be scaled beyond the number specified when it is being placed in the background image. If not specified, the background image size determines the maximum scale. |
Random Number Generator Seed |
RNG Seed can be used to reproduce the same results of samples generation. If the seed is left unspecified, the seed is determined randomly. |
Dialog Options - Tables
