ElevationExtractor
Extracts a feature’s first z coordinate value, storing it in an attribute.
Extracting elevations from geometry to an attribute for further processing.
The ElevationExtractor receives any type of geometry and extracts the z coordinate value of the feature’s first coordinate into an attribute.
If the input feature is 2D, the Elevation output attribute will receive a value of zero (0
Rasters, including elevation models, will also receive an elevation value of zero (0
In this example, we have a CAD file of 3D elevation points, and want to access the z values as an attribute.
The features are routed into an ElevationExtractor.
In the parameters dialog, the Elevation output attribute is left with its default name.
The output features have an elevation attribute containing the extracted values.
Features with an attribute containing elevation values.
Elevation |
Name the attribute to contain the elevation values. |
Dialog Options - Tables
Dependencies | None |
Aliases | |
History |
Search for all results about the ElevationExtractor on the FME Community.
