DimensionExtractor
Extracts a feature’s number of dimensions, storing the resulting value of 2
or 3
in an attribute.
Separating 2D and 3D features
Performing data quality testing
The DimensionExtractor receives any type of geometry and extracts the feature’s dimensionality into an attribute. The result will be either 2
or 3
, representing 2D or 3D geometry.
Note that all features, including those without geometry, will be either 2D or 3D.
In this example, we have a set of building footprints, some of which have been extruded to their above-ground height and made into 3D objects.
We want to isolate the features that are still 2D in order to work on them.
The features are first routed into a DimensionExtractor, and then on to an AttributeFilter to separate them.
In the parameters dialog of the DimensionExtractor, the default Output Attribute Name for Dimension is kept.
The features are then filtered based on the _dimension
attribute.
Inspecting the results from the 2 output port, we see only the 2D features, with a _dimension
attribute value of 2
Features with an attribute containing either 2
or 3
Dimension | Name the attribute to contain the dimension value, which will be either 2 or 3. |
Dialog Options - Tables
Dependencies | None |
Aliases | DimensionCalculator |
History |
Search for all results about the DimensionExtractor on the FME Community.
