Creating a Custom Format
There are several ways to take advantage of the data import capabilities
available in the
One of the more powerful methods involves creating a Custom Format. A custom format is ideal when you are regularly connecting to data in a set schema that requires processing.
For example, if you regularly receive text files in Comma-Separated Value (CSV) format, a custom format could be developed to create geometry from the CSV file, manipulate the attributes, and output linework. Once this custom format has been created, you can simply browse to any CSV dataset with the same schema, and the processing will happen automatically.
A Custom Format can only be an input format. When you create a Custom Format, you can, in effect, define your readers, your workflow, and the format's schema, and you can use it like a standard Reader. This is useful if you consistently use the same information in a translation, and when you consistently perform the same processing on datasets. After you create and save the format, it will be selectable from the Reader and Writer Gallery.
There are two ways to start:
- Export as a Custom Format.
- Use the Custom Format wizard.
Exporting as a Custom Format
Open an existing workspace and select File > Export as Custom Format. You will be prompted to enter a name and description. A new Workbench window will open, and the custom format information will appear in the title bar.
Using the Custom Format Wizard
To initiate the Custom Format wizard, select Tools > Browse Readers and Writers, and click the New button in the "Custom Formats" area at the bottom of the Gallery window.
The Custom Format wizard will guide you through the following steps:
Select the Source Format
Select the format of your source data. You can also click the Browse button to choose from the Reader and Writer Gallery.
Locate Source Data
Type the location of your input data. You can also browse for files or add multiple datasets. If the source format has specific default parameters that you want to change, you can edit them here by clicking the Parameters button. For help with Parameters, click the Help button in the parameter box.
Expose Parameters
The parameters listed here will depend on your source data, and the ones you select will determine which parameters will be shown when you use the format in a translation.
Name the Custom Format
Enter a short name and a description for the new format. When the format is saved to the Reader and Writer Gallery, the short name appears in the Short Name column, and the description appears in the Description column.
Create the Custom Format
Click Finish. Another instance of Workbench will start, displaying the custom format's feature types on the canvas. The Workbench title bar displays the default filename and file location. Like a regular workspace, you can do the following:
- include transformers
- edit feature types
- merge feature types
- fanout feature types
- add additional readers
- add destination feature types
The only visible difference between a Custom Format and a Workspace is that there is no destination dataset. You can, however, add destination feature type definitions, which become the source schema for the custom format.
See the FME Workbench help files for information on any of the tasks listed above.
Save the Format
Select File > Save. The custom format will be added to the Reader and Writer Gallery. All custom formats in the gallery are preceded by a custom format icon in the Description field, to distinguish them from standard FME-supported formats.
FME will automatically assign a default .fds file extension. The new
format will be stored, by default, in My Documents\FME\Formats.
Editing a Custom Format
From the Reader and Writer Gallery, choose the format, then click the Custom Formats > Edit button.
Deleting a Custom Format
From the Reader and Writer Gallery, choose the format, then click the Custom Formats > Delete button.
