RasterReplacer
Decodes a binary attribute containing encoded rasters stored as Blobs, replacing the feature’s geometry with the decoded raster.
- Restoring rasters previously extracted into an attribute by the RasterExtractor, often used to store rasters as Blobs in non-spatial databases.
- Creating geometry from rasters read with an AttributeFileReader transformer.
- Extracting images (such as photos) stored as Blobs on a feature.
The RasterReplacer receives features of any geometry type (or no geometry) that have rasters stored as Blob attribute of the feature, most often a result of having previously used the RasterExtractor to store them as Blob attributes to meet format or processing requirements.
The format of the encoded Blob raster must be provided. The attribute storing the Blob may be optionally removed after decoding and replacing the feature’s geometry with the raster. Removing the attribute reduces feature size and memory usage, and may improve performance.
Raster band and palette selection are not applicable to this transformer.
In this example, we will retrieve and decode a raster that was previously encoded with a RasterExtractor and loaded to a non-spatial database.
A database reader (PostgreSQL, in this case) reads the feature from the database table, which is then routed into a RasterReplacer.
Examining the feature as it exits the database reader, note that it has no geometry.
The first two attributes - _rasterblob and _rasterformatname - contain the encoded raster as a Blob, and the name of the encoding (GeoTIFF) used for the raster. Both of these attributes were originally created by the RasterExtractor.
In the RasterReplacer’s parameters dialog, Format is set to read the contents of the _rasterformatname attribute. We could alternatively set it explicitly to GeoTIFF, if we did not have an attribute providing that information.
Blob Attribute is set to _rasterblob, and Remove Attribute is set to Yes, which will remove the Blob attribute once it has been decoded and set as the feature’s geometry.
The output feature now has raster geometry, and the Blob attribute has been removed.
- This transformer only works with raster formats. Use the GeometryReplacer for vector formats or the PointCloudReplacer for point cloud formats.
- Different encoding formats may carry through different information. For example, GeoTIFF preserves coordinate system and extents, whereas PNG does not.
Choosing a Raster Transformer
Working with Rasters
| RasterConvolver |
| RasterRotationApplier |
Working with Bands
| RasterBandKeeper |
| RasterBandNodataRemover | Removes the existing Nodata identifier from selected bands of a raster feature. Any values previously equal to the Nodata value are considered valid data. |
| RasterBandNodataSetter | Sets a new Nodata value on selected bands of a raster feature. |
Working with Cells
| RasterAspectCalculator |
Working with Palettes
| RasterPaletteAdder |
| RasterPaletteNodataSetter |
Workflow Control
| RasterSelector |
Vectors and Rasters
| PointCloudOnRasterComponentSetter | Sets point cloud component values by overlaying a point cloud on a raster. The component values for each point are interpolated from band values at the point location. |
Features with rasters stored as attributes.
Features with their geometry replaced by the decoded rasters.
Features without a valid, decodable raster in the specified Blob Attribute will be routed to the <Rejected> port.
INVALID_FEATURE_CANNOT_READ_BLOB
| Format |
The raster format used to decode the Blob. May be set to an attribute value, or specified explicitly. Choices include:
| Blob Attribute | The attribute from which the blob will be read. |
| Remove Attribute | If Yes, the Blob Attribute will be removed from the output feature. |
Dialog Options - Tables
Search for all results about the RasterReplacer on the FME Community.
