RasterBandSeparator
Separates bands or unique band and palette combinations, and outputs either individual raster features or a single new raster feature containing all combinations.
- Isolating bands or palettes to meet format or processing requirements.
The RasterBandSeparator receives raster features and separates their bands and palettes into individual output raster features.
Raster features may be split by band, band and palette, or palette.
Separating by Band Only will produce multiple output features, one for each band.
Separating by Band and Palette will also produce multiple output features, one for every unique band and palette combination.
Separating by Palette Only will produce a single output feature per input feature, containing bands for every unique band and palette combination.
Attributes may be created to record which raster, band, and/or palette from which the output feature originated.
The order of the input features and their bands and palettes will determine the order of the output features. A Sorter transformer may be used to set the order in which the features are processed.
In this example, we will separate a multi-band orthoimage into its component bands.
Note that the original raster has three bands - red, green, and blue.
The raster is routed into a RasterBandSeparator.
In the parameters dialog, Split By is set to Band Only, and the Attributes to add remain with their default names.
Three raster features are output, one for each band in the input feature. Note that the feature viewed here in the FME Data Inspector was produced by the red band, and contains only that single band.
In table view, the three output features are listed. The _raster_index attribute indicates that all were created from the first raster feature received (0). The _band_index attribute refers to the original band, where 0 is red, 1 is green, and 2 is blue.
The input raster has no palettes, and therefore the _palette_index attribute is missing.
Choosing a Raster Transformer
Working with Rasters
| RasterConvolver |
| RasterRotationApplier |
Working with Bands
| RasterBandKeeper |
| RasterBandNodataRemover | Removes the existing Nodata identifier from selected bands of a raster feature. Any values previously equal to the Nodata value are considered valid data. |
| RasterBandNodataSetter | Sets a new Nodata value on selected bands of a raster feature. |
Working with Cells
| RasterAspectCalculator |
Working with Palettes
| RasterPaletteAdder |
| RasterPaletteNodataSetter |
Workflow Control
| RasterSelector |
Vectors and Rasters
| PointCloudOnRasterComponentSetter | Sets point cloud component values by overlaying a point cloud on a raster. The component values for each point are interpolated from band values at the point location. |
Raster features according to the raster and palette separation specifications.
INVALID_RASTER_NO_BANDS
| Split By |
Band Only: Each band on the input raster feature will be placed onto a unique output raster feature. Each output raster feature will have no more than one band, but each band may have multiple palettes. Band and Palette: Each unique combination of band and palette will be output to a separate raster feature. A band with multiple palettes will be output multiple times, once for each palette. Each output raster feature will have no more than one band and no more than one palette. Palette Only: One raster feature is output per input feature, containing one band for every unique combination of band and palette. A band with multiple palettes will be output multiple times, once for each palette. Each output raster feature may have multiple bands but will have no more than one palette per band. |
When using Split By - Band Only or Band and Palette, attributes may be added to the output raster to specify which raster, band, and palette it originated from.
Default attribute names are provided. If an attribute name is blank, it will not be added to the output features.
| Raster Index Attribute | Name the attribute to contain the index of the original input raster feature. |
| Band Index Attribute | Name the attribute to contain the index of the original raster band. |
| Palette Index Attribute | Name the attribute to contain the index of the original raster palette. |
Dialog Options - Tables
| Aliases | RasterBandSplitter |
| History | This transformer was previously known as the RasterBandSplitter. |
Search for all results about the RasterBandSeparator on the FME Community.
