RasterCellValueRounder
Rounds off raster cell values.
- Rounding cell values to a fixed number of decimal places
- Creating value ranges by rounding to powers of 10.
The RasterCellValueRounder receives raster features. All values on all bands are rounded according to the parameter selections.
Values may be rounded up, down, or to the nearest value, and are calculated to the specified number of decimal places. Negative decimal places may be used to round values to powers of ten - for example, -1 rounds to multiples of 10, -2 rounds to multiples of 100, and so on.
This transformer supports raster band selection. The RasterSelector can be used to modify selection.
Palettes are not supported.
In this example, we have elevations stored in a DEM dataset as Band 0 values, and want to round off these values to two decimal places.
The DEM is routed into a RasterCellValueRounder.
In the parameters dialog, we specify 2 decimal places, and select nearest rounding, which will round up or down as appropriate.
A raster feature is output, with new Band 0 values, rounded to 2 decimal places.
In this example, we will use negative rounding to create 10 meter elevation ranges in a DEM dataset. The elevations are stored as Band 0 values.
In the parameters dialog, we specify the Decimal Places as -1. This will round to the tens position.
The Round-off Direction is down. This will round all values in a 10 meter range to the starting number - that is, values like 21, 25, and 29 will all be rounded to 20.
A raster feature is output, with new Band 0 values rounded accordingly.
- If applying rounding to floating-point (decimal) values that are stored as real32, consider coercing the raster or band to interpretation type real64 prior to using this transformer to avoid unexpected results. The RasterInterpretationCoercer or RasterBandInterpretationCoercer may be used to do this.
FME’s internal calculations are performed in real64, which is considerably more precise than real32. By converting to real64 prior to using the transformer, the calculation result will not be converted twice (once to real64 for calculations, then again back to less-precise real32 for output), where error may be introduced. Values will be output as real64.
Choosing a Raster Transformer
Working with Rasters
| RasterConvolver |
| RasterRotationApplier |
Working with Bands
| RasterBandKeeper |
| RasterBandNodataRemover | Removes the existing Nodata identifier from selected bands of a raster feature. Any values previously equal to the Nodata value are considered valid data. |
| RasterBandNodataSetter | Sets a new Nodata value on selected bands of a raster feature. |
Working with Cells
| RasterAspectCalculator |
Working with Palettes
| RasterPaletteAdder |
| RasterPaletteNodataSetter |
Workflow Control
| RasterSelector |
Vectors and Rasters
| PointCloudOnRasterComponentSetter | Sets point cloud component values by overlaying a point cloud on a raster. The component values for each point are interpolated from band values at the point location. |
Raster feature(s) containing cells with values to be rounded.
Raster features with cell values replaced according to parameter selections.
INVALID_RASTER_NO_BANDS
EXTRA_A_RASTER_PALETTE
| Decimal Places |
Controls the number of decimal places to which the cell values are rounded. A value of 0 causes the cell values to be rounded to the nearest integer. A value of 1 causes rounding to the nearest tenth. Negative values are allowed. A value of -1 causes rounding to the nearest 10. |
| Round-off Direction |
Controls how the rounding will take place: Up: The cell values will always be rounded up. Down: The cell values will always be rounded down. Nearest (default): The cell values will be rounded up or down to the nearest value. |
Dialog Options - Tables
Search for all results about the RasterCellValueRounder on the FME Community.
