GridInQuestIIReprojector
Reprojects feature coordinates from one coordinate system to another using the Grid InQuestII engine from Ordnance Survey, for use in Great Britain, Ireland, and Northern Ireland.
Reprojecting features when explicitly using the Grid InQuestII engine is desired
The GridInquestIIReprojector receives raster, vector, or point cloud features and reprojects their coordinates from one coordinate system to another, using Ordnance Survey’s Grid InQuestII engine.
Its library allows you to transform coordinates between ETRS89 (WGS84) and the national coordinate systems of Great Britain, Northern Ireland and the Republic of Ireland.
The following coordinate systems are supported:
ETRS89 (WGS84)
UTM Zone 29N
UTM Zone 30N
UTM Zone 31N
Cartesian
Geodetic
OSGB36 British National Grid
Irish Grid
Irish Transverse Mercator
Two vertical datums are available, for Irish systems only:
Malin Head
Belfast
This transformer always reprojects from the source coordinate system to the destination coordinate system, tagging the features with the destination coordinate system on output.
Any coordinate system set on the input features is ignored - it is not able to read coordinate systems from incoming features.
- FME has a Workspace Parameter, Reprojection Engine, that may be set to either FME (CS-Map) or Esri. This transformer will override this parameter setting.
- The Reprojector provides similar functionality, and will use the default library (CS-Map or Esri) set in FME. It supports some of the same coordinate systems, but will not use the Grid InQuestII library.
Coordinate System Support
Library |
FME (default) or Esri |
Library (External Links) |
Sweden |
Sweden |
Switzerland |
Features with geometry to be reprojected.
Features reprojected as specified in parameters.
Source Coordinate System |
Specify the coordinate system of the input features. Choices include:
Source Coordinate System Version |
When Source Coordinate System is one of the following:
specify the version, either:
Select the coordinate system for the output features. Choices include:
Destination Coordinate System Version |
When Destination Coordinate System is one of the following:
Vertical Datum (Irish systems only) |
If required, select a vertical datum. Choices include:
This parameter is for the regions between Northern Ireland and the Republic of Ireland. |
Interpolation Type |
Select a method for interpolating reprojected cell values:
Cell Size |
Select a method for resizing cells:
Tolerance (cells) |
Sets the tolerance, in cells, for approximating reprojected cell locations. Using the default value of 0.0, every cell will be reprojected. If a value greater than 0.0 is specified, some cell locations will be approximated. The difference between an approximated cell location and the true cell location should be at most the tolerance value. For example, if a value of 0.5 is specified, each approximated cell location should be maximum one-half of a pixel away from its true location. Increasing the Tolerance value may improve performance. |
Dialog Options - Tables
| Dependencies | Ordnance Survey Grid InQuestII engine, provided with FME |
| Operating System Restrictions | Windows 32-bit and Windows 64-bit only |
Search for all results about the GridInquestIIReprojector on the FME Community.
