CommonLocalReprojector
Reprojects one or more features to a local coordinate system centered on the bounding box containing all features.
- Reprojecting multiple features into the same local coordinate system
The CommonLocalReprojector receives features and calculates their cumulative bounding box, then reprojects the features to a local coordinate system, centered on that box, with ground units in meters. The center of the data is used as the origin point to minimize and equalize distortion in all directions.
The Projection Type may be either Equidistant (AZMED) or Equal Area (ASMEA).
Reprojector vs. CommonLocalReprojector
The Reprojector can also reproject features to local coordinate systems, however, each feature is handled individually and receives its own coordinate system based on its bounding box. An example using neighborhood polygons is shown below (A). Each feature’s origin is at its center, and so they appear stacked on top of each other.
The CommonLocalReprojector creates a single local coordinate system that spans all of the input features, and applies it to all of them (B).
Z Values
Height is not considered so areas or distances are best preserved for geometry at an ellipsoid height of 0 meters. Despite height not affecting the coordinate system that will be generated, Z values may undergo a unit shift or geocentric to ellipsoid height conversion if a Vertical Handling mode of Heights are relative to the ellipsoid or geocentric is chosen.
In this example, we have a set of neighborhood polygons, in a UTM coordinate system. Note that the extents are appropriate coordinates.
We want to reproject these polygons to a single common local coordinate system.
The features are routed into a CommonLocalReprojector.
In the parameters dialog, we set Projection Type to Equidistant (AZMED), and leave Vertical Handling as its default, Ignore heights and leave them unchanged.
The features are output to a local coordinate system based on the bounding box of all input features.
- Rasters may only be reprojected in 2D (that is, with Vertical Handling set to Ignore heights and leave them unchanged).
Coordinate System Support
Library |
FME (default) or Esri |
Library (External Links) |
Sweden |
Sweden |
Switzerland |
Features reprojected to a new local coordinate system as specified in parameters.
Group By |
If blank, all features will be reprojected to the same local coordinate system. If attributes are specified, each group of features will be reprojected to a local coordinate system centered on that group. |
Group By Mode |
Projection Type |
Select a Projection Type based on whether preservation of distances or areas is more important. Choices include:
Vertical Handling |
Select a method for Z value handling:
Dialog Options - Tables
Yes |
Search for all results about the CommonLocalReprojector on the FME Community.
