FMEServerResourceConnector
Accesses the FME Server file storage service to upload, download, or delete files and folders or list information about files/folders from a FME Server account.
Jump to Configuration
- Access data stored on FME Server file storage without using FME Server
- Manage datasets on FME Server by uploading, downloading, and deleting files and folders
- Transfer a file's contents (such as XML or raster) into or out of an attribute in FME
- Read downloaded data using the FeatureReader, or upload data written by the FeatureWriter to FME Server
- Retrieve file and folder names, paths, and other information from FME Server to use elsewhere in a workspace.
The FMEServerResourceConnector uses your FME Server account credentials (either via a previously defined FME web connection, or by setting up a new FME web connection right from the transformer) to access the file storage service.
Depending on your choice of actions, it will upload or download files, folders, and attributes; list information from the service; or delete items from the service. On uploads, path attributes are added to the output features. On List actions, file/folder information is added as attributes.
Example: Downloading a dataset
In this example, the FMEServerResourceConnector is used to download an Autodesk AutoCAD DWG file from FME Server file storage. After creating a valid web connection to a FME Server account (which can be done right in the FME Server Account parameter), and browsing to the file, the Object ID is retrieved, and a destination for the download is selected.
A FeatureReader is added to read the newly downloaded dataset. Here, the ParcelLines feature type will be further processed elsewhere in the workspace.
By executing the download here in the workspace, the dataset will be refreshed every time the workspace is run.
Example: Downloading and using a raster as an attribute
In this example portion of a workspace, the FMEServerResourceConnector is used to download a raster orthoimage from FME Server file storage into an attribute.
The file is read from FME Server file storage, and the contents stored as a blob attribute. Then a RasterReplacer is used to interpret the blob into a usable raster format.
The combination of these two transformers avoids having to download the image to local storage and re-read it. A similar technique can be used for point cloud files, using the PointCloudReplacer transformer.
- This transformer cannot be used to directly move or copy files between different FME Server file storage locations. However, multiple FMEServerResourceConnectors can be used to accomplish these tasks.
- The FeatureReader can access FME Server file storage directly (without using the FMEServerResourceConnector), however, a local copy of the dataset will not be created.
Input
Output
The output of this transformer will vary depending on the FME Server Action performed.
- An Upload action will save the path of the file to an attribute.
- A Download action can save to either a folder or attribute.
- A Delete action has no output ports.
- Finally, a List action will output a new feature for each file/folder found in the path specified. Each of these new features will have attributes listing various pieces of information about the object.
<Rejected>
Features that cause the operation to fail are output through this port. An fme_rejection_code attribute, having the value ERROR_DURING_PROCESSING, will be added, along with a more descriptive fme_rejection_message attribute which contains more specific details as to the reason for the failure.
Note: If a feature comes in to the FMEServerResourceConnector already having a value for fme_rejection_code, this value will be removed.
Request
FME Server Action
The type of operation to perform. Choices include:
- Delete
- Download
- List
- Upload
FME Server Account
Performing operations against a FME Server account requires the use of OAuth2 authentication using a web connection. For more information, see Using Web Connections.
The remaining parameters available depend on the value of the FME Server Action parameter. Parameters for each FME Server Action are detailed below.
Parameters - Delete Action
FME Server Path
Object ID
The Object ID of a file or folder on FME Server to delete. If valid credentials have been provided as a web connection, you may browse to a location.
Parameters - Download Action
FME Server Source
Object ID
The FME Server path of the file/folder to download. If valid credentials have been provided as a web connection, you may browse to a location.
Destination
Download as
Select whether to store the downloaded data in a File, Folder or Attribute.
- File: The downloaded object will be stored in the specified folder.
- Folder: The downloaded folder object will be stored in the specified folder.
- Attribute: The downloaded object will be stored in the specified attribute. Note that this will always assume system encoding. Use the AttributeEncoder if your contents need to be a specific encoding type.
Download to Folder
Specify the path to the folder that will store the downloaded file. Valid for Download as File or Folder.
Include Subfolders
Choose whether to download subfolders of the FME Server Source or not. Valid for Download as Folder only.
Download to Attribute
Specify the attribute that will store the contents of the downloaded file. Valid for Download as Attribute only.
Note: FME will attempt to convert the attribute's contents to a UTF-8 string. If this fails, the attribute's contents will be created as raw binary. To ensure that the original bytes are always preserved and never converted to UTF-8, use Download as File instead.
Parameters - List Action
FME Server Path
Folder ID
The folder ID on FME Server to list the contents of. If valid credentials have been provided as a web connection, you may browse to a location.
Output Attributes
Default attribute names are provided, and may be overwritten.
File or Folder Name
Specify the attribute to hold the name of an object on FME Server.
File or Folder Path
Specify the attribute to hold the path of an object on FME Server.
File Size
Specify the attribute to hold the size of a file object on FME Server.
Last Modified
Specify the attribute to hold the last modified date of an object on FME Server.
File or Folder Flag
Specify the attribute to hold the type (file or folder) of an object on FME Server.
Relative Path
Specify the attribute to hold the relative path to an object on FME Server.
File or Folder Link
Specify the attribute to hold the link to an object on FME Server.
Direct Download Link
Specify the output attribute that will store a URL that links to the file on FME Server. The URL can only be used by authenticated users.
Parameters - Upload Action
Source
Upload
The source of the data to be uploaded.
File: The specified file will be uploaded.
Folder: The specified folder and its contents will be uploaded.
Attribute: The contents of the specified attribute will be uploaded.
When working with large objects, File is a better choice than Attribute as the data will be streamed directly from disk and not require that the object be stored entirely in memory on a feature.
FME Server treats file uploads of the same name, in a specific folder, as duplicates, and will automatically overwrite a file if it exists in the same folder.
When wanting to upload content from a folder, it is better to upload as a folder instead of setting a fixed path and sending multiple features into the connector to upload as a file.
File to Upload
The file to be uploaded to FME Server if Upload is set to File.
Folder to Upload
The folder to be uploaded to FME Server if Upload is set to Folder.
Include Subfolders
Choose whether to upload subfolders of the Folder to Upload or not.
Attribute to Upload as File
The data to be uploaded, supplied from an attribute if Upload is set to Attribute.
FME Server Destination
Folder ID
The path on FME Server to upload the source file to. You must choose a specific shared resource folder to upload your content to.
Upload with File Name
The name of the file created from the data supplied in Attribute to Upload as File. The name must include a filename extension (for example, .txt, .jpg, .doc).
Output Attributes
File or Folder Path
Specify the output attribute that will store the path of the file/folder that was just uploaded.
File or Folder Link
How to Set Parameter Values
Text Editor
Arithmetic Editor
Dialog Options - Tables
- Add a row
- Remove a row
- Move current row up one
- Move current row down one
- Move current row to top
- Move current row to bottom
- Cut a row - delete and copy to clipboard
- Copy a row to the clipboard
- Paste a row from the clipboard
Cut, copy, and paste may be used within a transformer, or between transformers.
Start typing a string, and the matrix will only display rows matching those characters. Searches all columns. This only affects the display of attributes within the transformer - it does not alter which attributes are output.
Generally resets the table to its initial state, and may provide additional options to remove invalid entries. Behavior varies between transformers.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies |
FME Server account
Aliases |
History |
Released FME 2017.0
Search for all results about the FMEServerResourceConnector on the FME Community.
