AzureBlobStorageConnector
Accesses the Azure Blob Storage file storage service to upload, download, or delete files and folders or list file/folder information from an Azure account.
Jump to Configuration
- Manage datasets on Blob Storage by uploading, downloading, and deleting files and folders
- Transfer a file's contents (such as XML or raster) into or out of an attribute in FME
- Read downloaded Blob Storage data using the FeatureReader, or upload data written by the FeatureWriter to Blob Storage
- Retrieve file and folder names, paths, links and other information from Blob Storage to use elsewhere in a workspace.
The AzureBlobStorageConnector uses your Azure Storage account credentials (either via a previously defined FME web connection, or by setting up a new FME web connection right from the transformer) to access the file storage service.
Depending on your choice of actions, it will upload or download files, folders, and attributes; list information from the service; or delete items from the service. On uploads, link attributes can be added to the output features. On List actions, file/folder information are added as attributes.
Example: Downloading a dataset
In this example, the AzureBlobStorageConnector is used to download an Esri Geodatabase from Blob Storage. After creating a valid web connection to an Azure Storage account (which can be done right in the Account parameter), and browsing to the geodatabase folder, the Container and Path to the object are retrieved, and a destination for the download is selected.
A FeatureReader is added to read the newly downloaded dataset. Here, the PostalAddress feature type will be further processed elsewhere in the workspace.
By executing the download here in the workspace, the geodatabase will be refreshed every time the workspace is run.
Example: Downloading and using a raster as an attribute
In this example portion of a workspace, the AzureBlobStorageConnector is used to download a raster orthoimage from Blob Storage into an attribute.
The file is read from Blob Storage, and the contents stored as a blob attribute. Then a RasterReplacer is used to interpret the blob into a usable raster format.
The combination of these two transformers avoids having to download the image to local storage and re-read it. A similar technique can be used for point cloud files, using the PointCloudReplacer transformer.
- This transformer cannot be used to directly move or copy files between different Azure Storage locations. However, multiple AzureBlobStorageConnectors can be used to accomplish these tasks.
- The FeatureReader can access Azure Blob Storage directly, without using the AzureBlobStorageConnector. In this case, a permanent local copy of the dataset will not be created.
Input
Output
The output of this transformer will vary depending on the action performed.
- After an Upload action, selected information about the file will be available as attributes.
- A Download action will output the incoming feature and can save to either a file, folder or attribute.
- A Delete action will output the incoming feature.
- A List action will output a new feature for each file/folder found in the path specified. Each of these new features will have attributes listing various pieces of information about the object.
Initiator
The incoming feature is output through this port.
<Rejected>
Features that cause the operation to fail are output through this port. An fme_rejection_code attribute, having the value ERROR_DURING_PROCESSING, will be added, along with a more descriptive fme_rejection_message attribute which contains more specific details as to the reason for the failure.
Note: If a feature comes in to the AzureBlobStorageConnector already having a value for fme_rejection_code, this value will be removed.
Authentication
Credential Source
The AzureBlobStorageConnector can use credentials from different sources. Using a web connection integrates best with FME, but in some cases, you may wish to use one of the other sources.
- Web Connection: - use an Azure Storage web connection stored in the FME web connections database
- SAS: - use a Shared Account Signature instead of an access key
- Embedded: - embed an account name and access key as parameters in the transformer
- Environment Variables: - use credentials already configured on the system, in the environment variables AZURE_STORAGE_ACCOUNT and AZURE_STORAGE_ACCESS_KEY
- Anonymous: - access public Blob Storage containers without authenticating
Account
Available when the credential source is Web Connection. To create an Azure Storage connection, click the 'Account' drop-down box and select 'Add Web Connection...'.
The connection can then be managed via Tools -> FME Options... -> Web Connections.
Account Name and Account Key
Available when the credential source is Embedded. An account name and access key can be specified directly in the transformer instead of in a web connection.
Account Name and Shared Access Signature Token
Available when the credential source is SAS. An account name and shared access signature can be specified directly in the transformer. |
Request
Action
The type of operation to perform. Choices include:
- Delete
- Download
- List
- Upload
The remaining parameters available depend on the value of the Request > Action parameter. Parameters for each Action are detailed below.
Parameters - Delete Action
Delete Options
Container
The container the file or folder is in. If valid credentials have been provided as a web connection, you may browse for a container.
Path
The full path of a file or folder on Blob Storage to delete. If valid credentials have been provided as a web connection, you may browse for a location.
Parameters - Download Action
Download Options
Container
Path
The full path of a file or folder on Blob Storage to download. If valid credentials have been provided as a web connection, you may browse for a location.
Start byte range
Start of byte range to use for downloading a section of the blob.
If no end_range is given, all bytes after the start_range will be downloaded.
The start_range and end_range params are inclusive.
Ex: start_range=0, end_range=511 will download first 512 bytes of blob
End byte range
End of byte range to use for downloading a section of the blob.
If end_range is given, start_range must be provided.
Ex: start_range=0, end_range=511 will download first 512 bytes of blob.
Destination
Download as
Select whether to store the downloaded data in a File, Folder or Attribute.
- File: The downloaded object will be stored in the specified folder.
- Folder: The downloaded folder object will be stored in the specified folder.
- Attribute: The downloaded object will be stored in the specified attribute.
Download to Attribute
Specify the attribute that will store the contents of the downloaded file. Valid for Download as Attribute only.
Response Body Encoding
For Download as Attribute, you can specify a character set encoding to ensure the output is in a human-readable form.
If Auto Detect from HTTP Header is specified but there is no encoding in the Content-Type metadata associated with the data, the output will be returned as raw bytes.
Download to Folder
Specify the path to the folder that will store the downloaded file. Valid for Download as File or Folder.
If File Exists
Specify what to do if the file already exists locally. Valid for Download as File or Folder.
- Reject: If downloading a file, the input feature will be rejected. If downloading a folder, a rejected feature will be output for each rejected file.
- Overwrite: Any existing local files or folders will be overwritten with the remote copy.
Include Subfolders
Choose whether to download subfolders of the Blob Storage source or not. Valid for Download as Folder only.
Output Attributes
The selected attributes will be added to the output feature.
_download_path
Path of the downloaded object on the local file system. This attribute will not be added for Download as Attribute.
Parameters - List Action
List Options
Container
The container the folder is in. If valid credentials have been provided as a web connection, you may browse for a container.
Path
The full path to the folder on Blob Storage to list. If valid credentials have been provided as a web connection, you may browse for a location.
Include Subfolders
If set to Yes, then subfolders are recursively traversed, and their contents are included in the result.
Output Attributes
_name
Name of the file or folder
_full_path
Full path of the file or folder
_url
URL to the file or folder.
_file_or_folder
Whether the item is a file or a folder
_file_size
File size (not present for folders)
_created
Date and time when the file was created
_last_modified
Date and time when the file was last modified
_relative_path
Path to the item relative to the list path
Parameters - Upload Action
Data Source
Upload
The type of data to be uploaded.
- File: The specified file will be uploaded.
- Folder: The specified folder and its contents will be uploaded.
- Attribute: The contents of the specified attribute will be uploaded.
When working with large objects, File is a better choice than Attribute, as the data will be streamed directly from disk and not require that the object be stored entirely in memory on a feature.
When wanting to upload content from a folder, it is better to upload as a folder instead of setting a fixed path and sending multiple features into the connector to upload as a file.
File to Upload
The file to be uploaded to Blob Storage if Upload is set to File.
Folder to Upload
The folder to be uploaded to Blob Storage if Upload is set to Folder.
Include Subfolders
Choose whether or not to upload subfolders of the Folder to Upload.
Contents Only
- Yes: Upload only the contents of the folder to the remote destination.
- No: Upload the folder to the remote destination.
Attribute to Upload as File
The data to be uploaded, supplied from an attribute if Upload is set to Attribute.
Upload Options
Container
Path
The full path to the folder on Blob Storage to upload to. If valid credentials have been provided as a web connection, you may browse for a location.
Upload with File Name
The name of the file created from the data supplied in Attribute to Upload as File. The name must include a filename extension (for example, .txt, .jpg, .doc).
If File Exists
Specify what to do if the file already exists on Blob Storage.
- Reject: If uploading a file, the input feature will be rejected. If uploading a folder, rejected files will be listed in the Rejected Files attribute.
- Overwrite: Any existing files or folders on Blob Storage will be overwritten with the local copy.
Maximum Block Size (MB)
The size of the blocks to create when uploading (provided the file is larger than 4MB). The maximum block size Azure Blob Storage supports is 100MB.
For more information about block size, see https://docs.microsoft.com/en-us/rest/api/storageservices/understanding-block-blobs--append-blobs--and-page-blobs
Metadata
It is possible to specify custom name-value pairs that are associated with the uploaded features.
Generate Shared Access Signature
If checked, a Shared Access Signature (SAS) will be generated for the uploaded file. The attributes _sas_url and _sas_token will be added to the output feature. This option is only available for file and attribute upload. For more information about SAS, please see the Microsoft Azure documentation.
SAS Token Expiry Time
When the token should expire.
IP Address or Range
If provided, restrict access to an IP address or range of IP addresses. Ranges are given in the format “203.0.113.0–203.0.113.255”. |
Restrict to HTTPS
If Yes, the token can only be used via HTTPS.
Output Attributes
The selected attributes will be added to the output feature. Only available for file and folder uploads.
_name
Name of the file or folder.
_full_path
Full path of the file or folder. |
_url
How to Set Parameter Values
Text Editor
Arithmetic Editor
Dialog Options - Tables
- Add a row
- Remove a row
- Move current row up one
- Move current row down one
- Move current row to top
- Move current row to bottom
- Cut a row - delete and copy to clipboard
- Copy a row to the clipboard
- Paste a row from the clipboard
Cut, copy, and paste may be used within a transformer, or between transformers.
Start typing a string, and the matrix will only display rows matching those characters. Searches all columns. This only affects the display of attributes within the transformer - it does not alter which attributes are output.
Generally resets the table to its initial state, and may provide additional options to remove invalid entries. Behavior varies between transformers.
Processing Behavior
Feature-Based
Feature Holding
No
Dependencies |
Azure Storage Account
Aliases |
History |
Released FME 2019.0
Search for all results about the AzureBlobStorageConnector on the FME Community.
