Teradata Spatial Quick Facts
Format Type Identifier |
TERADATA_JDBC_SPATIAL |
Reader/Writer |
Both |
Licensing Level |
Professional and above |
Dependencies |
Requires Teradata JDBC drivers, which are not installed with FME. You can download the drivers from: http://downloads.teradata.com/download/connectivity/jdbc-driver The .jar files in the downloaded archive must be placed in FME_HOME/plugins. |
Dataset Type |
Database name |
Feature Type |
Table name |
Typical File Extensions |
Not applicable |
Automated Translation Support |
Yes |
User-Defined Attributes |
Yes |
Coordinate System Support |
Yes |
Generic Color Support |
Spatial Index |
Yes |
Schema Required |
Yes |
Transaction Support | Yes |
Encoding Support | Yes |
Geometry Type | teradata_type |
Teradata Spatial Geometry Support
Geometry | Supported? |
aggregate |
yes |
circles |
no |
circular arc |
no |
donut polygon |
yes |
elliptical arc |
no |
ellipses |
no |
line |
yes |
none |
yes |
point |
yes |
polygon |
yes |
raster |
no |
solid |
no |
surface |
no |
text |
no |
z values |
no |
