SAP HANA Spatial Writer Feature Type: User Attributes
For information on the parameters in this dialog that are common to all readers, see:
For information on the parameters in this dialog that are common to all writers, see:
User attributes for this format are defined below.
Name | The name of the field to be written. |
Type |
This section describes the attribute types for a table. ![]() Represents strings of up to 127 alpha-numeric characters. ![]() Represents 64-bit signed integers. ![]() Represents a large-object that can hold character strings or binary data. This type is only supported in column tables. ![]() Represents variable-length binary data up to a length of 2 GB. ![]() Represents variable-length ASCII character data up to a length of 2 GB. ![]() Represents date data from January 1, 0001 to December 31, 9999. ![]() Represents fixed precision and scale numeric data. ![]() Represents 64-bit floating precision numbers. ![]() Represents 32-bit signed integers. ![]() Represents variable-length Unicode character data up to a length of 2 GB. ![]() Represents variable-length Unicode character data up to a length of 5000 characters. ![]() Represents 32-bit floating precision numbers. ![]() Represents date and time data from January 1, 1900 to June 6, 2079 with an accuracy of one second. ![]() Represents 16-bit signed integers. ![]() Represents a variable-length character string. It is only supported for column tables. ![]() Represents a large-object character string. It is only supported for column tables. ![]() This type is used to store geometry of one or more types. ![]() This type is used to store 2D points. ![]() This type is used to represent time data with an accuracy of up to one second. ![]() This type is used to represent date and time data from January 1, 0001 to December 31, 9999 with an accuracy of up to 100 nanoseconds. ![]() This type is used to represent numbers between 0 and 255. ![]() This type is used to represent variable-length ASCII character data up to a length of 5000 bytes. ![]() This type is used to represent variable-length binary data up to a length of 5000 bytes. |
Index |
This type is used to create bitmap indexes. A bitmap index stores a bitmap for each index key. Each index key stores pointers to multiple rows. They are primarily designed for data warehousing or environments in which queries reference many columns in an ad hoc fashion. Indexes and constraints are only created if the table is created. The valid values for the column type are listed below: PrimaryKey: This type specifies that the column is a primary key for the table. Only one primary key is allowed per table. Unique: This type specifies that the column has a UNIQUE constraint. NotNull: A non-nullable constraint. UniqueNotNull: An index with a non-nullable and unique constraints. |
