OpenStreetMap (OSM) XML Writer: User Attributes
For information on the parameters in this dialog that are common to all readers, see:
For information on the parameters in this dialog that are common to all writers, see:
User attributes for this format are defined below.
Name |
The name of the column to be written. |
Type |
The type of a column in a table. The valid values for the column type are listed below: ![]() Represents logical Boolean values (true/false). ![]() Represents a fixed-length character string of a specified length, including trailing blanks (if any). The maximum length is 4096 bytes. These strings are always padded with spaces, so a CHAR(10) column always occupies 10 bytes of storage. ![]() Represents a calendar date (year, month, day). Use this type to store simple calendar dates without timestamps. It ranges from 4713 BC to 294276 AD with a resolution of 1 day. ![]() Represents a single-precision floating-point number. This is an inexact storage type, meaning that values are stored as approximations and may result in slight discrepancies. It has up to 6 significant digits of precision. ![]() Represents a double-precision floating-point number. This is an inexact storage type, meaning that values are stored as approximations and may result in slight discrepancies. It has up to 15 significant digits of precision. ![]() Represents a signed 2-byte integer. It ranges from -32768 to +32767. ![]() Represents a signed 4-byte integer. It ranges from -2147483648 to +2147483647. ![]() Represents a signed 8-byte integer. It ranges from -9223372036854775808 to +9223372036854775807. ![]() Represents a complete timestamp value that includes the date and the time of day. The values are UTC, not local time. It ranges from 4173 BC to 294276 AD with a resolution of 1 microsecond (up to a maximum of 6 digits of precision for fractional seconds). ![]() Represents a variable-length character string with a user-defined limit. This type supports UTF-8 multibyte characters up to a maximum of four bytes. So a VARCHAR(120) column consists of a maximum of 120 single-byte characters, 60 two-byte characters, 40 three-byte characters or 30 four-byte characters. The maximum length is 65535 bytes (64K – 1). VARCHAR values are not padded with spaces. |
