Google Cloud SQL Non-Spatial (MYSQL_GOOGLE_DB) Writer: User Attributes
For information on the parameters in this dialog that are common to all readers, see:
For information on the parameters in this dialog that are common to all writers, see:
User attributes for this format are defined below.
Name
The name of the field to be written.
Valid values for field name include any character string devoid of SQL-offensive characters and less than 63 characters in length.
Type
The type of a column in a table. The valid values for the field type are listed below:
bigint
blob
char(width)
date
datetime
decimal(width, precision)
double(width, precision)
float(width, precision)
int
longblob
longtext
mediumblob
mediumint
mediumtext
smallint
text
time
timestamp
tinyblob
tinyint
tinytext
varchar(width)
year
Index
The type of index to create for the column. The valid values for the index type are listed below:
  • BTree: B-Tree-based geometry index (default attribute index)
  • Hash: Hash-based geometry index
  • PrimaryKey: Any primary key or identity attribute
