Microsoft SQL Server and Azure SQL Database Spatial (JDBC) Writer: User Attributes
For information on the parameters in this dialog that are common to all readers, see:
For information on the parameters in this dialog that are common to all writers, see:
User attributes for this format are defined below.
Name The name of the field to be written.
Type
Choose one of the following field types.
Index
The types of indexes and constraints to create for the column, if the table is created.
Each index and constraint contains only one column.
The valid values for the column type are listed below:
PrimaryKey: A primary key with non-nullable and unique constraints.
Unique: An index with a unique constraint.
NotNull: A non-nullable constraint.
