IBM Informix Non-Spatial (JDBC) Reader: Feature Type Parameters
To access feature type parameters, click the gear icon on a feature type in the workspace to open the Feature Type Parameter Editor. To always display the editor in Workbench, you can select View > Windows > Parameter Editor.
General
All feature types share similar General parameters, which may include the Feature Type Name, Reader or Writer Name, and Geometry.
In most Writer Feature Type parameter dialogs, you can also control Dynamic Schema Definitions. Some database formats accept a Table Qualifier prefix on the output table feature type.
See Editing Writer Feature Types for more information.
These parameters apply only to a selected feature type, not to the entire writer.
Tip: If a feature type parameter listed here conflicts with a writer-level parameter, then the writer parameter will be ignored and this feature type parameter will be used.
Table
To construct a WHERE clause, click the browse button to open the Where Clause editor. You can also type a WHERE clause directly in the parameter field.
If the WHERE clause SQL is invalid, the translation will fail.
