Feature Types and User Attributes
Fixed Schema
The user attributes for this format come from the schema; they are visible in the Feature Type > User Attributes tab, but you cannot modify them.
route_points
Geometry type: fme_point
Feature Attribute | Description |
cmt | Comment for the waypoint. |
desc
Description of the waypoint. |
ele |
Elevation, in meters. |
name |
Name of the point. If not provided, the name is RouteXXXX, where XXXX is an auto-incrementing counter. |
sym |
Name of the symbol for the point. If not provided, the default is “Waypoint”. The name must be a recognized Garmin icon name. “Bell” is used for unrecognized symbol names. For a list of valid symbol names, refer to garmin_tables.c in the GPSBabel source code. The source for GPSBabel is available at http://www.gpsbabel.org. |
time |
Creation date/time, in UTC. When writing, times that have time zones will be converted to UTC. Format: YYYYMMDDHHMMSS |
route_fid | ID of the route to which the point belongs. |
route_point_id | ID of the point in the route. |
route_name | Name of the route. Valid only for the first point in the route. |
routes
Geometry type: fme_line
name |
Name of the route. To provide a value for this attribute when using route_points, use the route_name attribute on the first point. The default is RouteXXXXXX, where XXXXXX is an automatically-generated alphanumeric identifier. |
track_points
ele | Elevation in meters. |
track_fid (Required) |
ID of the track feature to which the point belongs. |
track_seg_id (Required) |
ID of the track segment to which the point belongs. |
track_seg_point_id (Required) |
ID of the point. |
track_name | Name of the track. Valid only for the first point in a track. |
tracks
Geometry type: fme_aggregate of lines
name |
Name of the track. To provide a value for this attribute when using track_points, use the track_name attribute on the first point. The default is TrackXXXXXX, where XXXXXX is an automatically-generated alphanumeric identifier. |
waypoints
desc |
ele |
name |
Name of the point. If not provided, the name is WPTXXX, where XXX is an auto-incrementing counter. |
sym |
time |
