Feature Representation
In addition to the generic FME feature attributes that FME Workbench adds to all features (see About Feature Type Attributes), this format also adds format-specific attributes (Format Attributes).
ArcGIS Image Server features specify a matrix of x, y, and z coordinates. For each raster, there will only be a single feature returned.
Attribute Name
Contents
arcgis_image_server_type
This will always be arcgis_image_server_raster.
arcgis_image_server_service_
name
The image service reference file path or the url path.
title
The title given to the image service. This is generally different but related to the name.
edition
The edition of the image service similar to a version number.
identifier
A unique ID for the image service and version number. If the image service is changed, this value should also be changed. It may be used to track the lineage of an image service.
geographic_region
A geographic region, such as town, state, or country.
pixel_unit
A description of the pixel values. The default list provides some examples, including True Color;False Color; NDVI Legend;Radiance;Elevation m; and Elevation ft. Other values can exist.
pixel_source
A description of the source from which the pixel values are obtained. This is generally the sensor type or original source. The default list provides some examples, including Aerial Photography; Landsat; QuickBird; Scanned Maps; SRTM; and Mixed. Other values can exist.
process_summary
A summary of the processing applied by the image service to the raw imagery.
originator
The originator of the image service.
publisher
The publisher of the image service.
arcgis_image_server_service_rights
The owner or owners of the rights to the data and image service.
contact_organization
The contact organization for the image service.
contact_person
The contact person for the image service.
time_period_begin
The date of the first image added in the image service.
time_period_end
The date of the last image added in the image service.
creation_date
The date the image service was created.
creation_time
The time the image service was created.
modification_date
The date the image service was last modified.
modification_time
The time the image service was last modified.
abstract
The abstract of the image service.
arcgis_image_server_service_purpose
The purpose of the image service.
arcgis_image_server_version
The version number of the ArcGIS Image Server in the dataset.
