You are here: Installing > Installing FME Desktop on Linux > Multiple Installations of FME Desktop in Parallel
If you want to have multiple of installations of FME Desktop on the same system, we recommend the following procedure:
- Install the first copy of FME Desktop as described in Installing FME Desktop on Linux.
- Copy the contents of the install directory (/opt/fme-desktop-<release>) to another location (for example, /home/user/fme-desktop-b18228).
- Install the second copy of FME Desktop as described in Installing FME Desktop on Linux.
- Run the first copy of FME Desktop directly from the location to which it was copied (for example, /home/user/fme-desktop-b18228) - not from a desktop shortcut. You can run the second copy of FME Desktop from a desktop shortcut, which points to the original install location (/opt/fme-desktop-<release>).
