Download and Run the Installer (Three-Server Redundant Floating License Server)
The FME installer contains the utility program that is needed to get the license server up and running:
fme-flexnet-win-x86.msi
or
fme-flexnet-win-x64.msi
You can download the installer from Safe Software’s site:
http://www.safe.com/support/support-resources/fme-downloads/
If you are viewing this link in a PDF file, your Acrobat security settings may prevent access to the installer. You can paste the above link into a web browser.
The table that follows lists the shortcuts that are created in the Safe Software program group:
Shortcut |
Description |
Generate hostid.txt |
Creates a text file to send to codes@safe.com. |
Launch LMTOOLS |
Launches LMTOOLS. Used for debugging or changing configuration. |
License Administration Guide |
Opens Flexera Software’s License Administration Guide. |
Start - Restart FME License Server |
Starts the license manager process. |
View FME License Server Log |
Opens the license manager log file. Used for debugging. |
View hostid.txt |
Reopens text file, if required by Safe Software. |
View Readme |
Opens the installation and configuration instructions. |
Install the floating license server on three different computers using the instructions in the previous sections.
Send an e-mail to codes@safe.com and include the FlexNet Host ID, the hostname assigned to each of the computers, and serial number. To get your serial number, see the confirmation e-mail you received after purchasing FME Desktop.
We will e-mail you a file called safe.lic that contains the key code file for the license code servers. Copy the safe.lic file into each of the FlexServer directories on your license server nodes.
What's Next?
