You are here: Reference Manual > FME Server Services > Notification Service > Subscribers > Overriding Behavior Using Notification Keywords
The Amazon S3 subscriber also allows you to override certain configurable fields in the incoming notification (see Configuring the Subscriber) with the following keywords:
Keyword Field Overridden Notes
aws_access_key AWS Access Key ID
aws_secret_key AWS Secret Key
s3_bucket Bucket
s3_remote_dest Destination Path
s3_local_src Source Path
s3_encryption Encryption Must be "None" or "SSE"
s3_version Enable File Versioning Must be "Default", "Yes" or "No"
s3_permission Permissions Must be "PRIVATE", "PUBLIC_READ", "PUBLIC_WRITE", "AUTH_READ", "BUCKET_READ", or "BUCKET_FULL". For more information, see: http://docs.aws.amazon.com/AmazonS3/latest/dev/ACLOverview.html#CannedACL.
Example
Consider the following subscription configuration:
If the incoming notification contains none of the configurable keywords, the subscription fails to upload the specified data due to the fake Amazon security credentials.
If the incoming notification contains:
"aws_access_key":"AKIAIRJZIINGIEF5PQNA",
"aws_secret_key":"680Yq3GRSK2N8ktZF7uouIFxfRdPSm4LD/WKwa6r",
The specified file (test.txt) is uploaded to the root of bucket samplebucket.
"s3_bucket":"mybucket",
"s3_remote_dest":"myfolders/testfolder",
"s3_local_src":"C:\\work\\",
"s3_encryption":"SSE",
"s3_version":"Yes"
"s3_permission":"PRIVATE"
The entire folder C:/work/ is uploaded to folder myfolders/testfolder inside bucket mybucket. Before the data is uploaded, file versioning is enabled, and the data is encrypted by Amazon S3.
