You are here: Reference Manual > FME Server Services > Notification Service > Subscribers > Configuring the Subscriber
- In the FME Server Web User Interface, select Manage > Notifications. Select the Subscriptions tab and click “New”.
- Subscription Name: Provide a name for the Subscription
- Topics Subscribed To: Select the topics you want to subscribe to and click Add. Or, click Add All to subscribe to all topics.
- Protocol: Select Amazon S3.
- Bucket: Complete the “Bucket” field with the bucket name. The name is case sensitive.
- AWS Access Key ID and AWS Secret Access Key: Provide your security credentials. For more information, see AWS Security Credentials.
- Encryption: (Optional) Enable Amazon S3 Server-Side Encryption. When enabled, Amazon S3 encrypts your data using AES-256 as it writes to disk in its data centers.
- Permissions: The predefined set of grantees and permissions to store with each uploaded object. The default is Private. For more information about predefined grants, see Access Control List (ACL) Overview > Canned ACL, in the AWS Documentation, at: http://docs.aws.amazon.com/AmazonS3/latest/dev/ACLOverview.html#CannedACL.
- Destination Path: (Optional) Provide a location in the specified Bucket , using forward slashes (/).
- myfolders/testfolder
- /myfolders/testfolder
- //myfolders/testfolder
- myfolders/testfolder/
- /myfolders/testfolder/
- Source Path: Provide the full path to the file/folder to be uploaded. The path must be specified with either forward slashes (/) or escaped backslashes (\\). Template macros are supported for this field; for an example, see Creating an FTP Subscription.
- Enable File Versioning: (Optional) Enable/disable versioning for the specified bucket. Leave as “Default” if you do not have permission to set bucket versioning or to maintain the current behavior.
For example, any of the following is acceptable:
If left blank, objects are uploaded to the bucket’s root. If the specified folder does not exist in the bucket, it is created during the upload.
