Class FMERectangleFace
object --+
FMEGeometry --+
FMESurface --+
FMESimpleSurface --+
FMERectangleFace
init(MultipleInvocations)
Create an instance of a Rectangle Face geometry object.
init()
Default FMERectangleFace constructor.
Returns: FMERectangleFace
An instance of a Rectangle Face Geometry object.
init(coordinates)
The rectangle has to be parallel to a coordinate plane (i.e one of XY,
XZ, or YZ plane). The first and second points are the either the min and
max or max and min points of the rectangle face. If the first point is
the min point, then the normal of the rectangle is in the positive
direction of the plane it is parallel to..
coordinates (tuple) - tuple of coordinates in form
(firstx, firsty, firstz, secondx, secondy, secondz).
init(coordinates, matrix)
matrix (list of lists of
floats) - transformation matrix applied to the
rectangle face , formatted [[dddd][dddd][dddd]].
init(rectangleFace)
Create a copy of the passed in Rectangle Face geometry object.
rectangleFace FMERectangleFace - The Rectangle Face
geometry object to create a copy of.
__init__(MultipleInvocations)
x.__init__(...) initializes x; see help(type(x)) for signature |
FMEFace
FMELine
tuple of floats
getLocalFirstPointXYZ()
Gets the coordinates of the first point of this rectangular face,
prior to transformation. |
tuple of floats
getLocalSecondPointXYZ()
Gets the coordinates of the second point of this rectangular face,
list of lists of floats
bool
None
removeTransformationMatrix()
Removes this rectangle face's transformation matrix. |
None
setLocalFirstPointXYZ(x,
y,
z)
Sets the coordinates of the lower point of this rectangular face,
None
setLocalSecondPointXYZ(x,
y,
z)
setTransformationMatrix(matrix)
Sets this rectangle face's transformation matrix, replacing the
existing matrix if it exists. |
Inherited from FMESimpleSurface:
numParts
Inherited from FMESurface:
__decIterRef__,
__incIterRef__,
__iter__,
deleteSide,
getAppearanceReference,
getAsWireFrame,
isInPlane,
isOriented,
isPlanar,
offset,
orient,
reorient,
reverse,
rotate2D,
scale,
setAppearanceReference,
sideExists
Inherited from FMEGeometry:
__getObject__,
__new__,
boundingBox,
boundingCube,
bounds,
clearMeasures,
copyAttributesFromFeature,
copyNameFromGeometry,
copyTraitsFromGeometry,
copyTraitsToFeature,
deleteName,
force2D,
force3D,
getArea,
getMeasureNames,
getName,
getTrait,
getTraitNames,
getTraitNullMissingAndType,
getTraitType,
hasMeasures,
hasName,
is3D,
isCollection,
measureExists,
removeMeasure,
removeTraits,
renameMeasure,
setName,
setTrait,
setTraitNullWithType
Inherited from object:
__delattr__,
__format__,
__getattribute__,
__hash__,
__reduce__,
__reduce_ex__,
__repr__,
__setattr__,
__sizeof__,
__str__,
__subclasshook__
__class__
(Constructor)
- Overrides:
object.__init__
Returns a copy of this face.
- Returns: FMEFace
- A copy of the face
Return a copy of this rectangle's boundary as a line.
- Returns: FMELine
- The rectangle face's boundary as a line
- Returns:
tuple of floats
- The coordinate value of the point.
- Returns:
tuple of floats
getTransformationMatrix()
Gets this rectangle face's transformation matrix. If the rectangle
face does not have such a matrix, an identity matrix is returned. Only
the top three rows of the matrix will be returned, as he bottom row is
always [ 0 0 0 1 ].
- Returns:
- The rectangleFace's tranformation matrix, formatted
hasTransformationMatrix()
This method determines if the rectangle face has a transformation
matrix or not.
- Returns:
bool
- Returns
True if this rectangle face has a
transformation matrix, and False otherwise.
y,
z)
- Parameters:
x (float) - The x value.
y (float) - The y value.
z (float) - (Optional) The z value.
- Returns:
None
y,
z)
- Parameters:
- Returns:
None
existing matrix if it exists. Only three rows are expected in the input
array, as a bottom row of [ 0 0 0 1 ] is assumed.
- Parameters:
matrix (list of lists of floats) - The transformation matrix, formatted
[[dddd][dddd][dddd]].@rtype: None
