| Home | Trees | Indices | Help |
object --+
FMELibraryIterator
init()
FMELibraryIterator should not be constructed directly. Instead, use the iterator semantics of FMELibrary to get an FMELibraryIterator which can be used to iterate over its librarys.
| a new object with type S, a subtype of T |
FMEAppearance or None
FMETexture or None
int
| the next value, or raise StopIteration |
Inherited from |
Inherited from |
x.__init__(...) initializes x; see help(type(x)) for signature
This method returns a copy of the current shared object as an
appearance if type() returns FME_LIB_APPEARANCE. Otherwise, it returns
This method returns a copy of the current shared object as a texture
if type() returns FME_LIB_TEXTURE. Otherwise, it returns
Returns the object's reference from the FMELibrary.
This method returns the type of the current shared object.@rtype:
| Generated by Epydoc 3.0.1 on Thu Nov 26 19:10:16 2015 | http://epydoc.sourceforge.net |
