FME Dialog class.
Provides access to the standard FME dialog boxes.
__init__()
x.__init__(...) initializes x; see help(type(x)) for signature |
a new object with type S, a subtype of T
about(applicationName)
This method displays a dialog box that shows the kind of FME license
and FME build number that the FMEObjects application is using. |
string or None
coordSysPrompt(coordSysName)
This method displays a standard FME coordinate system dialog to
prompt the user to choose a coordinate system. |
tuple of strings and list of
strings or None
destPrompt(defaultDestFormat,
defaultDestDataset,
userDirectives)
This method displays a dialog to prompt the user to choose a
destination format and dataset. |
FMEFeature or None
featTypeProperties(format,
source,
schemaFeat)
Bring up the feature type properties dialog on the given schema
feature. |
tuple of strings
generate(parameterFileName,
workspaceFileName)
This method displays the GenerateWorkspace dialog box. |
string or None
guessFormat(filename)
This method attempts to guess the format based on the extension of
the filename passed in. |
bool
parameterPrompt(filename)
This method parses the file with the passed in name and does a
standard FME dialog for the parameters listed in the GUI lines in the
file. |
strings or None
sourcePrompt(defaultSourceFormat,
defaultSourceDataset,
userDirectives)
This method displays a dialog to prompt the user to choose a source
strings or None
xlatePrompt(defaultSourceFormat,
defaultDestFormat,
defaultDestDataset,
userDirectives)
Inherited from object:
__delattr__,
__format__,
__getattribute__,
__hash__,
__reduce__,
__reduce_ex__,
__repr__,
__setattr__,
__sizeof__,
__str__,
__subclasshook__
