| Home | Trees | Indices | Help |
object --+
FMECSGSolidIterator
init()
FMECSGSolidIterator should not be constructed directly. Instead, use the iterator semantics of FMECSGSolid to get an FMECSGSolidIterator which can be used to iterate over its geometries.
| a new object with type S, a subtype of T |
int
FMESolid or
None
bool
bool
bool
| the next value, or raise StopIteration |
Inherited from |
Inherited from |
x.__init__(...) initializes x; see help(type(x)) for signature
This method returns a valid CSG Boolean Operator if isLeaf() returns
This method returns the same solid as next() but if the CSG solid has a transformation matrix, the matrix is NOT applied to the leaf solid when returned. This method must be called after next().
This method returns
This method returns
This method returns
| Generated by Epydoc 3.0.1 on Thu Nov 26 19:10:16 2015 | http://epydoc.sourceforge.net |
