Writer Overview
The dataset is the destination filename. The feature type of each dataset is the filename.
The TomTom POI writer will only write data in decimal degrees (WGS84 datum). All features passed to the writer will be reprojected to LL84 (EPSG:4326) if this functionality is licensed. Features with no coordinate system are assumed to be in LL84.
The TomTom POI writer uses a fixed schema.
Unicode attribute writing is not supported. Accented characters are replaced with unaccented equivalents. Other Unicode characters are replaced with “$”.
Workbench Writer Parameters
This format does not contain format-specific writer-level parameters.
