TFS Variable Schema Quick Facts
Format Type Identifier |
TFS_VARIABLESCHEMA (C++) TFS_VARIABLESCHEMA_JAVA (Java) |
Reader/Writer | Both |
Licensing Level | Professional |
Dependencies | None |
Dataset Type | Folder or File |
Feature Type | File base name (exceptions are possible) |
Typical File Extensions |
.tfs |
Automated Translation Support |
Yes |
User-Defined Attributes |
Yes |
Coordinate System Support |
Yes |
Generic Color Support |
Spatial Index |
Schema Required |
Yes |
Transaction Support |
Geometry Type |
tfs_type |
Encoding Support | Yes |
TFS Variable Schema Geometry Support
Geometry |
Supported? |
aggregate | yes |
circles |
yes |
circular arc |
yes |
donut polygon |
yes |
elliptical arc |
yes |
ellipses |
yes |
line |
yes |
none |
yes |
point | yes |
polygon |
yes |
raster |
no |
solid |
yes (C++) no (Java) |
surface |
text |
yes |
z values |
yes |
